trans leak
trans leak
have a 2004 tl auto with trans fluid leaking from the oil cooler banjo bolt washers the one with the jet to second gear. theres a tsb on it i changed the washers and torqued. still leaked tighten some more now small leak, dont want to tighten any more aluminum. anyone else have this prob. thanks
I had a banjo joint in my transmission leaking that I didn't know about. Acura found it when doing a fluid change. Got it fixed under warranty, If you are out of warranty I suggest you talk to the Service Manager and see if they can help you out
IBankMouse
06-13-2020 01:53 PM
