TRans code P0757- Shift Solenoid Valve B Stuck ON
Wife's car got this code, cant clear. Out of warranty. Any info/ help would be great. It is down hard. Thnking I will just try replacing the dual shift solenoid unit on top of trans.
I'm sure someone else will chime in with exactly which one is shift solenoid B but out of curiosity, is it driving normal?
Usually it will only have one or two gears when one of the solenoids go out.
First step would be to find which plug it is and check the connector.
Ends up one of the output half shaft drive axle seals failed and dumped fuid out. I filled it and it runs fine but has a steady leak out of one half shaft. Anyone know a parts breakdown link that shows the trans case output shaft seals?
The seal is in that diagram, I just checked it. Keep in mind that the seal can be damaged when you have bad diff bearings and other things too.
#20. The diagram is not very good, you would have to rotate it 180 degrees to see the section of the trans that it goes in.
mada51589
05-03-2022 08:54 PM
jamestheunderdog
07-19-2016 07:58 PM
