Trans blew at an intersection...
Old Feb 29, 2016 | 06:41 PM
TheTLProject's Avatar
Life is not so good for me. My 06 TL 5AT just blew the trans. Car rolls backward when on a slight downgrade when put into drive, reverse, park or low. I'm fucked. How much will this cost to replace
Old Feb 29, 2016 | 07:23 PM
FamilyGuy's Avatar
That sucks dude hope it's salvageable. Good excuse to trade for a 6spd though
Old Feb 29, 2016 | 08:00 PM
No check engine light, just rolls backward when on a hill in park, reverse, drive or low.
Old Feb 29, 2016 | 08:01 PM
No leaks either. Tow truck guy owns a shop and thinks it's my torque converter bolts, or the whole torque converter
Old Feb 29, 2016 | 08:03 PM
pohljm's Avatar
its not just an axle is it?
Old Feb 29, 2016 | 08:08 PM
I couldn't have snapped an axle could I? Here's the mods in case it matters
AEM 3.25 inch Cold Air Intake
ATLP V2 J-Pipe
JE Test Pipe
XLR8 2.5 inch Base Duals Cat-Back
Vibrant 2.5 inch Inlet/Outlet Ultra Quiet Resonator
RV6 Hi-Flow PreCats x2
J37 Intake Manifold
J37 Throttle Body
P2RJ37 Throttle Body Spacer
P2R J37 Intake Manifold Spacer
P2R J37 TB Thermal Gasket x2
P2R J37 IM Thermal Gasket x1
Throttle Body Coolant Bypass
AEM Fuel/Ignition Controller (Not plugged up).
Old Feb 29, 2016 | 08:09 PM
And how expensive would and an axle be
Old Feb 29, 2016 | 09:54 PM
crazyasiantl's Avatar
That's what my 2G did when I snapped an axle. It's a cheap fix.
Old Feb 29, 2016 | 10:07 PM
anx1300c's Avatar
Sounds like an axle to me. If the trans was slipping, it would still lock in park. If a car rolls in park as the only abnormal symptom, it's usually an issue with the parking pawl. Broken axle will cause both symptoms.
Old Mar 1, 2016 | 12:25 AM
pohljm's Avatar
ATLP V2 J-Pipe
JE Test Pipe
J37 Intake Manifold
J37 Throttle Body
Nope! impossible to have snapped an axle with those mods.
Old Mar 1, 2016 | 06:24 AM
Yeah it's def gotta be an axle. I'm running out of money though. I have 800 left to spend. If it's BOTH axles I'm gonna be waiting a while
Old Mar 1, 2016 | 09:21 AM
FamilyGuy's Avatar
Acuraoemparts.com good discounts
Old Mar 1, 2016 | 09:28 AM
myron's Avatar
same happened to friends car right in front of me at a light turning left. I was wandering why his car was reversing slowly when he's got an automatic. Axle snapped when he went to give it gas. It happens
Old Mar 1, 2016 | 10:02 AM
Yeah, hopefully I can have my car back before the week is over
Old Mar 1, 2016 | 10:29 AM
I had my buddies dad replace my axles. I think he charged me 200 with a three year warranty. They weren't OEM axles though.
Old Mar 1, 2016 | 10:32 AM
TacoBello's Avatar
Didn't everyone warn you about modding a car with an 04-06 5AT in it?
Hopefully that's not what the problem is, but either way, you're on borrowed time. We are not trying to misguide you when we say you should pick up a 6MT TL instead, if you want to drive hard and fast. You'd be faster and much more reliable with that manual transmission
Old Mar 1, 2016 | 10:34 AM
Did you learn by blowing trannies?
Old Mar 1, 2016 | 10:47 AM
TacoBello's Avatar
Old Mar 1, 2016 | 10:49 AM
beanertypes's Avatar
I wonder why ACURA never had the option for reman axles on the 3RD gen
Old Mar 1, 2016 | 02:31 PM
Official word is in and will only cost 250 to fix. Shattered drivers side axle.
Will be done tomm
Old Mar 1, 2016 | 03:55 PM
pohljm's Avatar
you need to take a breath or two before starting a thread and jumping to the worst possibility. obvious it was an axle
Old Mar 1, 2016 | 05:46 PM
I think I need my user name changed to "Critical Chris" because I do this with everything.
Old Mar 5, 2016 | 10:36 AM
6MTSSR's Avatar
Originally Posted by crazyasiantl
did you learn by blowing trannies?
lmmfao!!
Old Mar 5, 2016 | 12:45 PM
More like "Jump the Gun and Drama Queen Chris"
Old Mar 5, 2016 | 01:20 PM
TacoBello's Avatar
Why are you discriminating against drama queens? I feel like I'm being singled out and attacked here. MODS!!! MOOOOODS!!!!
666wokker
Apr 15, 2026 03:06 PM
bindermike
1G RDX (2007-2012)
Jan 16, 2016 04:55 PM
