tranny stuck in second? auto
08 Tl auto
i was on my way to work this morning and a semi pulled in front of me so i floored it to get around and then a car pulled in front of me so i took my foot off the gas abruptly.
my rpm sayed high, my car was not downshifting on its own, i was in auto mode. so then i flipped it to sport shift mode and it showed to be in second gear. i then flipped it back to auto and still it was stuck in second. it did not downshift on its own till i had slowed down and reach about 30mph.
the car is brand new(on a lease).
has this happed to anyone else? i had an 05 rsx-s befor this and there was a third gear issue with all those cars.
i know honda tranny have a sort-of bad track record..
if it happends again ill take it to acura.
is there any sort of additive for the auto tranny fluid? i know the 6sp'd you can use syncromax for the syncros.
its a known glitch with the VSA system in the exact senario you posted. Honda is working on a fix for it according to one of the guys in service who spoke to acura techline.
I have car ADD
happened in my 06 TL 2 or 3 times in a similar situation... hard accelerating that was abruptly stopped.... i switched to manual mode, and tried to up-shift into 3rd... didnt work.. once i slowed the car back down to around 20/30mph, it slipped into 3rd on its own
hasnt happened really on my 08 TL-S, but sometimes the gradelogic tranny pisses me off when im going down hill in auto mode.. it forces into 2nd, i switch to manual mode, push into 3rd, go back to auto, and it goes back into 2nd!! it stays at like 4k+ RPM when going down hill... i guess it takes stress of the brakes when going down a steep grade, but it definitely has to be putting more stress on the tranny
wow, that's a pretty serious glitch there
take it to the dealer- could be brake system or trans problem
Needs dealer diagnosis on this one
LOVES HIS TL!!!
Old thread, but i figured i would chime in. I had the exact scenerio 2 or 3 times already on my 08. I am taking it in next week. I was able to get it to go back to normal by putting it in neutral then back to D. I couldnt go down to 20 - 30 MPH like someone suggested... would have been hard to do so on the parkway.
Does anyone have an update on this issue? maybe some dealer expierences?
lanechanger
10-13-2015 10:56 AM
