Tranny maintenence
Old Sep 15, 2014 | 12:53 PM
blownby's Avatar
Tranny maintenence
Ok,
So recently got a new to me 05 TL....112K miles.
Supposedly all scheduled maintenance on the car was done.
Car was very clean and well kept so I am going with that it all being done.
Transmission in general seems to be working fine too.
Did so reading and here is what I plan to do.
3qts Honda fluid every oil change until i go through 9 qts.
Did the first of these a month back.
Then I will change drain & fill 3 qts every other oil chg.
Now I have read a little about the 3rd & 4th gear pressure switches. I plan to change these, but could use part number to order them up.
Also anything else I should consider? Any other pressure switches or just the 3rd & 4th gear?
Thanks,
Old Sep 15, 2014 | 12:59 PM
paperboy42190's Avatar
fluids and pressure switches. thats about it. there is a big diy thread here regarding the switches, diy, and all the part numbers
Old Sep 15, 2014 | 01:04 PM
zsameer's Avatar
Acura Parts @ AcuraOEMparts.com - Genuine Acura OEM Parts from Delray Acura
you will need #12, 13 and 2 of 17 just for the 3rd and 4th pressure switches. There are the only two you can change. Some also change the filter element which I did as well but its a bit of PIA but still doable. If you decide to do that as well then you will need more parts. The thread for filter change is : https://acurazine.com/forums/problem...tridge-731052/
Hope this helps.
Old Sep 15, 2014 | 01:15 PM
blownby's Avatar
Hope this helps.
exactly what i was looking for!!
I have heard there is a filter somewhere! Thanks,
Next go i will do the 3 qts, filter and pressure switches.
Pham Alvan
May 18, 2021 06:48 AM
Charles Bennett
Jan 28, 2018 08:53 PM
Pham Alvan
Mar 16, 2016 09:17 AM
LeVeL
Oct 18, 2015 04:19 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
