Tranny fluid funnel
Old Nov 17, 2011 | 12:58 PM
spaceboy's Avatar
Tranny fluid funnel
planning to change the ATF soon but having a hard time trying to find the correct size of the funnel because the filler hole is so small..every funnel i see happens to be bigger or just a bit bigger...ahhhh..this is driving me crazy....did u guys use a funnel or something else? btw, its a
Old Nov 17, 2011 | 01:25 PM
RaviNJCLs's Avatar
The filler hole is not that small. It is about 0.75 inch across. I just bought a long neck black funnel at Walmart and it works fine.
Old Nov 17, 2011 | 01:31 PM
spaceboy's Avatar
u got a pix of that thing?
Old Nov 17, 2011 | 01:35 PM
RaviNJCLs's Avatar
http://www.autozone.com/autozone/acc...er=421152_0_0_
There you go. It's something like that one. You should be able to get it at any parts place or Walmart.
I take it this is the first time you are doing this.
You should make sure you get an extra quart of fluid. I have done it twice and both times I drained 3.5 quarts. And get a new washer. It is very easy to do. Did the last one on Monday. It really improved my shifting.
Old Nov 17, 2011 | 01:39 PM
spaceboy's Avatar
Cool, thanks a lot...
btw, doesn't the owner manual say the capacity is 2.5qt??
Old Nov 18, 2011 | 08:33 AM
myblack04tl's Avatar
I just fill it up using the dipstick hole. I put a turkey baster in the dipstick hole and then put in a skinny longer funnel into that and fill er' up.
3 quarts is what drains out on mine and I've drained it about 8 times now.
I probably won't be using the turkey baster this Thanksgiving
Old Nov 18, 2011 | 08:45 AM
SharksBreath's Avatar
BANNED
i'm with ravin, more than 3 quarts came out of mine too...probably closer to 3.5 but i just cut it off at 3 so that i could keep track of how much fluid i was taking out and replacing.
Old Nov 18, 2011 | 09:02 AM
RaviNJCLs's Avatar
Check level before you start. If you are within the range then refill what you drain out. I stopped mine about 0.5 short and checked the level. I ended up adding the extra 0.5.
BTW....the name's Ravi....not ravin.
Old Nov 18, 2011 | 09:04 AM
RaviNJCLs's Avatar
Seems like a PITA. The fill plug is really not that hard to get to.
Old Nov 18, 2011 | 09:06 AM
BANNED
sorry ravi...
yeah i just took a 1 gal. milk jug and marked the outside with a sharpie at the 3 qt. mark. drained exactly 3 out and put three back in so i know it's dead on.
drove around for a bit and then immediatley rechecked the fluid. good to go.
Old Nov 18, 2011 | 10:03 AM
RaviNJCLs's Avatar
sorry ravi...
Old Nov 18, 2011 | 12:17 PM
spaceboy's Avatar
I ended up getting one of these
http://www.autozone.com/autozone/acc...er=574855_0_0_
not gonna use the pump, just gonna fit the end of the hose into the filler hole and put a funnel on the other end....the hose fits perfectly into the filler hole....hohohohoho!!!
Old Nov 18, 2011 | 01:02 PM
RaviNJCLs's Avatar
Cool. Just don't jam the hose down inside the tranny and watch that the end does not come out of the hole when filling.
Wow....jam the hose down inside the tranny....that sounded gay.
Old Nov 18, 2011 | 01:10 PM
spaceboy's Avatar
i noticed there is an ATF filler plug not too far away from the dipstick, but it looks too much pain in the ass to take off due to the limited space
Old Nov 18, 2011 | 01:17 PM
RaviNJCLs's Avatar
It is very easy. All you have to do it move the upper fuse box. To do that there are 2 bolts and a clip. Once you move that use a 12 inch extension, a 17mm socket and a breaker bar to loosen it. Pretty sure it is a 17mm.
Reach down with your hands to remove the bolt and the washer. Be careful with the washer.
Start to finish....5 minutes. And that includes taking a sip of beer.
https://acurazine.com/forums/3g-tl-2004-2008-93/c-026-diy-changing-atf-pics-745892/
Old Nov 18, 2011 | 01:51 PM
spaceboy's Avatar
the prob is i dont have a 12" extension.....lol
Old Nov 18, 2011 | 01:59 PM
RaviNJCLs's Avatar
I see....$8 at Sears.
Old Nov 18, 2011 | 02:03 PM
BANNED
Old Nov 21, 2011 | 11:31 AM
How is that a PITA? In less than 10 seconds the turkey baster with funnel is in the dipstick hole.
My method is quicker AND allows me to drink 3 of your beers.
Old Nov 21, 2011 | 11:01 PM
RaviNJCLs's Avatar
I like the way you drink my friend. I have done the 1x3 a couple times now using the fill bolt and no issues.
SidhuSaaB
May 30, 2020 12:40 AM
LeVeL
Oct 18, 2015 04:19 PM
lanechanger
Oct 13, 2015 10:56 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
