Tpms light on
Tpms light on
WELL it has been 4 months and every month my car is at the dealership for the right front tire light is on and they looked at time and nothing wrong called client service and nothing from them.. just sent them a long letter the dealer can not even fix it all i know is that every day the tire is low 4psi and i am ny and it was 65 degress and the light was on and all the sensors are working
Seems relatively simple, especially if the pressure is low. If you know a tire shop, take it to them to have them determine where the leak might be, object in tire, leaking valve, or sensor seal is leaking.
Are you manually checking the tire pressure? Inflate the tire to 80% of it's max rating and manually check the psi everyday. If it is indeed losing pressure get the tire and wheel checked out.
well i ck them all the time and the tpms light sensor not working acura does not know how to fix it. And i called client services they are the worst i have ever seen. So i aksed them for a buyback now. Since the car is still not repaired.
mada51589
Jan 9, 2025 04:40 PM
