Tpms
5th Gear
Tpms
Hi,
I have a problem today with the tire pressure system it was giving telling me tire pressure error but it is functioning normally as the info. I got this error when I start and then warm the car up as soon as I hit the first turn the info pop out just wondering if it is because of the cold temperature outside affecting the system.
Same problem here. It was below 0 degrees today and the monitor said to check the driver side front pressure when I first started the car. After a couple minutes of driving it went away.
It is possible that the pressure is just out of spec low in your driver side front tire, due to the cold temperature. After you drive a couple of minutes the tire starts to warm, resulting in a pressure increase. In the morning, before you start to drive, I would check all four of your tires using a tire gauge. If you find the pressure low, add some air. The proper cold pressure is identified on the car info plate in the drivers door area.
neuronbob
23
07-16-2019 10:48 AM
