Tough problem.... Professional opinion needed
There seems to be a lot of knowledgeable people checking this thread, so here goes...
I replaced my OEM brakes (fronts & rears) at 65k miles with the XRL8 Acurazine brake package of Stoptech slotted rotors and Stoptech performance pads. They now have two years/22k on them with no issues whatsoever.
I had my clutch/flywheel replaced at a stealership about 3 months ago, which would require them to take apart most of the front wheel/brake/drivetrain components. I've put at least 2000 miles on the car since, but just now am getting a lot of brake vibration coming to a stop from almost any speed except parking lot cruising.
What could cause this? I'm sure they used a air gun to tighten the lugs, so yesterday I loosened and re-tightened them to 80 ft/lbs. Inspection of the rotors seemed like uniform wear. Is there any other piece I should check (caliper pins, etc) to try to diagnose. The car is my DD, but not driven or braked overly-aggressively. Would "resetting" the lugs make the problem slowly go away if that was the issue?
Anyone else had problems with Stoptech stuff? Seems too soon to have the rotors go bad. Plenty of pad left too. Could the rotors be wearing down and the slots are creating the vibrations?
There seems to be a lot of knowledgeable people and a single idiot checking this thread, so here goes...
First question: Did you notice the vibration right after your clutch replacement?
Does the car pull to a certain side while braking or any other noises that might indicate a problem other than brakes? My thought here is a possible compliance bushing concern.
I just want to point out to you that when they replaced your clutch,they at least partially removed the axles (left the outboard joints in the knuckles), unbolted the lower ball joints,removed the front subframe COMPLETELY,and proceeded with the actual clutch replacement.
Also, i use an impact gun to run down my lugs and haven't had a rotor warp..yet.
obviously i don't run them down forever, just a couple of quick bursts usually has them snug enough. Now,who's to say the technician that performed your clutch replacement isn't quite as careful? or that he is super anal, there's a tech at my dealer that goes around the car checking the torque on the lugs of every car he works on at least 2-3 times.If i were you, go back to them. Tell them the vibration started right after the clutch replacement and you want to know what the cause is. If they determine it's a bad rotor, they should know the runout and be able to give you the specs.
Hokay, so:
I don't get any side to side movement during braking at any speed. Just very substantial vibration (it rattles my house keys in the ignition!)
Wild idea, since the brembo calipers are so easy to pop the pads out, what if I rotated them to the other side?? I think I might go to the dealer tomorrow and see if they can take a look at the rotors. They likely won't want to resurface since they are slotted, but as you said, they can at least let me know if that is the problem.
While on the subject, is it normal for brakes to drag slightly when first driving the car in the morning? I can hear the pads scraping for the first 1/2 mile or so, or until I make a hard stop.
cycdaniel
Dec 17, 2019 10:58 AM
Mugen TSX
Eastern Canada
Sep 1, 2015 11:11 PM
