Torqe Steer Help
Old Jul 14, 2012 | 03:53 PM
Sethjason's Avatar
Torqe Steer Help
So I have this 08 TL Type S. i can never romp the pedal in 1st gear cause the wheels break free and the car has crazy torque steer. This sucker is an auto.
Anyone have any suggestions for suspension adjustments or add on parts to help reduce the wheel spin and/or torque steer.
Seth
Old Jul 14, 2012 | 04:00 PM
Undying Dreams's Avatar
Tires would be a great place to start. But the TL and Type-S is known for torque steer, it's nearly 300hp and FWD, it's normal.
Old Jul 14, 2012 | 04:01 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
as far as i know...torque steer is a normal characteristic of this car.
Old Jul 14, 2012 | 04:04 PM
YeuEmMaiMai's Avatar
get better tires. Torque Steer isn't crazy like that unless you got weak tires (Acura does an AWESOME job of hiding it considering the HP they are working with)
Old Jul 14, 2012 | 04:14 PM
paperboy42190's Avatar
not gonna lie, i dont think this car has that much torque steer....i have hankook v12's and i can floor it in 1st gear no problem. it'll have a bit of wheelspin for the first second or two, then it just grips on afterwards. as long as im holding the steering wheel firmly, it'll go straight no problems
Old Jul 14, 2012 | 04:56 PM
Redsand353's Avatar
I like turtles
maybe something is wrong with your car?? the type-s is the most powerful fwd car I have owned, yet has the least torque steer i have experienced....
Old Jul 14, 2012 | 05:30 PM
07_J35A8_noob's Avatar
say wattt??
just don't turn the VSA off when u floor it..
Old Jul 14, 2012 | 05:58 PM
BukvaMan's Avatar
i wish my car would have torque steer as my car has no torque whatsoever.... I'm happy when i can brake the tires lose, which is very rare in my case.
Old Jul 14, 2012 | 07:21 PM
I hate cars's Avatar
These cars have very little true torque steer. Breaking the tires free causing jerking side to side is different. Stop the tires from spinning and you will fix the problem. Get better tires. If you have adjustable shocks, stiffen the rebound setting.
alexb92's Avatar
I only get torque steer when I floor it while taking a sharp (or any turn), otherwise if I'm going straight even from a stop I get practically 0 torque steer.
Old Jul 14, 2012 | 07:22 PM
That's exactly how mine is.
Old Jul 14, 2012 | 07:56 PM
CBMACURATL06's Avatar
^ 2nd that.
Old Jul 14, 2012 | 08:30 PM
con5tant's Avatar
Does the auto UA7 come with LSD?
Old Jul 14, 2012 | 09:12 PM
vietxquangstah's Avatar
no, only 6spd models
Old Jul 14, 2012 | 11:11 PM
Otacon's Avatar
flappy paddles
Tires, rebound adjustment and motor mounts are good places to start to combat torque steer.
Old Jul 14, 2012 | 11:24 PM
con5tant's Avatar
If you think the auto torque steer is bad...the 6MT is x2 worse because of the LSD
Old Jul 14, 2012 | 11:28 PM
truonghthe's Avatar
there is almost no torque steer at all in my TL-S.
Old Jul 15, 2012 | 03:58 PM
vectorracer's Avatar
couldn't say it better
Old Jul 16, 2012 | 12:45 AM
Blankachip's Avatar
crazy torque steer on mine especially coming out of turns
Old Jul 16, 2012 | 06:28 AM
thats expected.
its a fwd car...
dont come out so hot in a corner...duh
Old Jul 16, 2012 | 12:55 PM
NJAcura2004's Avatar
A little torque steer is normal as many members have already stated. The only thing I would add is to check your front axles to make sure the cv-joints are not seized. I had ridiculous torque steer and vibrations and it was being caused by the cv joints. After i replaced both front half-shafts the vibration and torque steer went away.
Old Jul 17, 2012 | 01:49 AM
AnthraciteAspec's Avatar
RPF1+RS3 FTW
Get better tires
Jul 16, 2017 07:33 AM
spudweb
May 22, 2016 02:39 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
Euro4gen
Dec 12, 2015 03:14 AM
