TL won't crank has buzzing sound under dash
So when I start the car it primes to the fuel pump and everything but then it has a buzzing sound coming from under the dash. I'm having the exact problem this guy is having please help with any clues
http://www.youtube.com/watch?v=bu49t...ature=youtu.be
I have a new starter cause I thought it was going out and didn't fix the buzzing and new battery please help
Asian Persuasion
This is the exact problem I have please help me out
https://acurazine.com/forums/showthread.php?t=875747
I believe I had to replace one of the relays or fuses. I changed the pcm myself but was in court when one of the relays or fuses got replaced. I think it was the starter relay.
Nkmndz (01-09-2014)
mattymattB (01-15-2014)
551.00 later and new a starter and ignition switch and problem solved. If i would have acted sooner, i could have probably fixed this by replacing the ignition switch 1st. But i drove with it for months like this(where id turned the key, it would buzz, and i would just keep turning off and on until the starter engaged). The mechanic told me by doing that it eventually shorted out the starter.
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
