tl-s rattle
Old May 9, 2007 | 04:59 PM
tupacboy1's Avatar
tl-s rattle
Hi guys,
I'm getting a rattle in my dashboard near the right side... can't seem to find the problem. Any ideas?
Old May 9, 2007 | 05:05 PM
tupacboy1's Avatar
i forgot to mention i did search.. but wasn't sure if the tl-s dash is different somehow... sorry i'm a noob...
Old May 10, 2007 | 11:51 AM
ACER's Avatar
Empire of The Sun
You Think After 4 Years, They Would Of Fixed All These Damn Rattles
Old May 14, 2007 | 06:09 PM
joelsaxton's Avatar
Joel Saxton
I have the same intermittent problem in the front dash and also the back panel behind the back seat. I think it might be the speakers, but not sure. It makes a creaking plasticy kind of sound.
Old Aug 6, 2007 | 04:31 PM
alkemist03's Avatar
7th Gear
Dashboard Rattle
I have a 1 month old 07 Acura TL-S which has developed (or maybe I am just now hearing it) a rattle that seems to be coming from behind the NAV or system display (where the time is displayed). It doesn't do it all the time and it is hard to hear with the radio on. I normally hear it when I turn the wheel sharply one way and then another (like a serpentine test). Occasionally, I hear it when I hit a bump. I wonder if we are hearing the same rattle or if they are different. I am reluctant to bring my car in for service for this rattle b/c I am afraid that there are so many parts that will have to be taken apart and put back together that even if they happen to find the problem, they will create more rattles. Please let me know if you find your rattle.
Old Aug 7, 2007 | 06:05 PM
antlive's Avatar
Cruiser
I discovered that the plasitc trim inserts rattles on the doors and possibly on the console. These parts get swaped out do to the interior you choose. I plan to take mine back to acura and point this out.
Old Aug 12, 2007 | 02:50 AM
SteeleTM's Avatar
check your side view mirror.
Old Aug 12, 2007 | 04:44 AM
kennyc's Avatar
not vtech... VTEC!!!
I'd say check your center speaker - just hold it down and see if the rattle goes away.
Old Aug 12, 2007 | 10:34 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
I dropped a quarter inside my cup holder, how do I get it out, it rattles when I pull off or turn, I needed that quarter too, wanted to get a pack of gum, I was 1 quarter short, I want it back, how do I get rid of this rattle heheeh, joking but I am serious... pm me if you know what to do
Old Aug 12, 2007 | 10:50 AM
leo_love's Avatar
4th Gear
just had dealer fixed that, it's the speaker
Old Aug 13, 2007 | 08:41 PM
alkemist03's Avatar
7th Gear
Dashboard Rattle
I tried pressing down on the speaker. Still rattles. I drove onto a parking lot and jerked the steering wheel back and forth to make it rattle. Definately sounds like it is coming from directly behind either the clock or NAV. I took the speaker out and shook it around hoping. No good. I felt all around in the opening and shook anything I could touch. I tried dropping a small magnet down there to see if I could latch on to something loose and metallic. No good. I even tried poking around with a straw to see if I could reproduce the sound. Still no good. I give up. I was hoping to avoid this, but tomorrow I plan to schedule an appointment with the dealership. I am sure they will fix it. It is really quite obviously, like a loose screw rolling around in a cavity.
Old Aug 13, 2007 | 09:25 PM
HQTL6SPD's Avatar
get an exhaust, you will never notice rattles again!
Old Aug 13, 2007 | 10:10 PM
csmeance's Avatar
well, they at least did a few things to minimize the rattles, such as putting felt.velvet on the undersides of the headrests to reduce rubbing rattles and put cloth on various internal parts to reduce rattles.
Old Aug 24, 2007 | 06:52 AM
alkemist03's Avatar
7th Gear
Rattle is fixed, at least temporarily. I had the car serviced and the service manager determined that something was rolling around in the duct work. Apparently, after trying several methods to extract the object, he used compressed air in an attempt to eject the item. Unfortunately, he did not see anything fly out, but the rattle has disappeared. I can only hope that the item came out and he just didn't see it; otherwise, there is a chance that the object may cause problems somewhere down the road. I've driven the car for about a week now and have put quite a few miles (~300) on it since it was serviced and, so far, all is quiet on that front. Now, I need to fix the infamous rear deck rattle. Based on other posts in this forum, that should be fairly easy.
MetalGearTypeS
Aug 29, 2016 08:28 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
Timmy18
Oct 17, 2015 03:58 PM
Acura604
Sep 28, 2015 12:24 PM
UA7_Ando
Sep 28, 2015 07:53 AM
