Timing belt movement (slack)
Old 04-30-2017, 07:58 PM
8th Gear
PileofSticks's Avatar
I removed the timing belt cover while replacing the belt tensioner and idler assembly recently and I noticed the timing belt bowed in easily when pushing in from the "outside". Is this normal? I plan on swapping the TB soon but I don't know if I should just park the car for now. The car has 148k miles. Perhaps having just replaced the serpentine belt I feel like the TB should be much "tighter" than it was.
Please see my video below. Forgive my ignorance if this is a simple inquiry but I don't have much mechanical experience.
Thank you!
https://youtu.be/3ojg5no75_0
Old 05-01-2017, 04:13 PM
Turbonut's Avatar
Did you turn the crank at all? Even a "tight" belt can have some slack depending how the crank is turned. Best to turn the engine over a few times to be certain that the timing marks are correct.
