"Tighten fuel cap" message
Old Jun 15, 2014 | 11:44 PM
Jeff1187's Avatar
9th Gear
Hey all, I've recently noticed that my "Tighten fuel cap" light comes on once in a while (once every few months). Everytime I've checked, the cap has been on tight, but it always happens while I'm driving. Does anyone have an idea of what's causing this?
Old Jun 16, 2014 | 02:33 AM
paperboy42190's Avatar
very common problem. a quick search will yield you the exact answer
Old Jun 16, 2014 | 09:12 AM
Jesstzn's Avatar
Your answer is 7 or 8 posts down.
Old Jun 17, 2014 | 08:07 PM
Orjinal's Avatar
6th Gear
I had a similar issue before, but it ended up being the seal was cracked. In that case you can make it as tight as it goes but the light will still come back on. Check if the seal is cracked/broken.
Old Jun 23, 2014 | 07:14 PM
Fogz's Avatar
7th Gear
I've had the same issues for 3 years now. on my 07 Type-S Acura Dealership said my gas cap looked good and there was no point replacing it and that it's a sensor that is causing the error message. They quoted me about $180 to fix the sensor and have the error stop... I said I'll just ignore the error.
joflewbyu2
Oct 8, 2015 11:16 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
jmaxima03
Sep 27, 2015 10:22 AM
rockyboy
Sep 25, 2015 10:44 AM
Brandle34
Sep 23, 2015 07:20 PM
