Throttle problem on an '05 TL: Any thoughts?
Old May 12, 2011 | 09:21 PM
NGADriver's Avatar
3rd Gear
I love my car. And it loves me back with 163,000 miles on it. The problem first happened in 09/2010. Then not again until three weeks ago, and it's happened 7 times since.
During normal driving and between 1500 & 2000 RPM, there is a fluctuation in throttle engagement as though I'm lifting off the gas (I'm not). Then suddenly, my Engine light, ABS light, VSA light, and "!" light display, throttle pressure drops BUT the engine doesn't stall. I simply have to turn off the ignition and restart the car...which is tricky at 70 mph. When I restart, all lights but the engine light turn off. Then by next morning, even the engine light is off.
The techs just reset the codes cause they can't duplicate what happens. Any thoughts?
Old May 12, 2011 | 09:32 PM
automatic or 6speedmanual?
Old May 12, 2011 | 09:38 PM
NGADriver's Avatar
3rd Gear
Its an automatic.
Old May 12, 2011 | 09:44 PM
the techs didnt tell you what code was displayed?
I wonder if you can go to autozone or any parts store to see if the code is still present.
if you know what code was thrown, then diagnosing the problem is much easier.
Old May 12, 2011 | 10:18 PM
scubasteve05's Avatar
I had a similar problem with my '03 TL and found out there was something wrong with the cruise control...even though I wasn't using it. You might want to check to see if that might have something to do with it. I had the cruise control module and the cable replaced and drove an additional 60,000 miles before I sold it without any reoccurrance.
Let us know if you find something out.
Old May 13, 2011 | 02:41 PM
NGADriver's Avatar
3rd Gear
Thank you for the tips. At present, I'm trying to be cost conscious. Though, I'm completely lost on this one. I will post when I learn more.
cycdaniel
Dec 17, 2019 10:58 AM
spidermankb
Mar 5, 2019 11:34 AM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
PortlandRL
Sep 14, 2015 12:01 PM
