Throttle actuator control module relay malfunction
Old Nov 18, 2020 | 07:30 PM
hero2ky4's Avatar
7th Gear
I worked on AC in 2005 Acura TL, after which I keep getting the code p2552. check engine lights are on and car won't accelerate at all. All the connectors are in correctly and fully seated on the harness. If i disconnect the battery and drive it's fine but when i turn it off and back on CEL come back on.
How do I resolved it
Old Nov 18, 2020 | 08:37 PM
peter6's Avatar
What kind of work did you do?
The relay that this code relates to is behind the glove box, in front of the cabin filter housing.
Relay gets power from under-dash fuse #1 (15A) which should have battery voltage all the time - check both sides of the fuse with test light
Power from the relay goes to the throttle control module, which is also behind the glove box.
So check fuse first, then relay, then the control module. Get yourself a service manual and diagram to make life easier.
https://acurazine.com/forums/third-g.../#post15344256
Write what you find out.
maceio4
1G RDX Problems & Fixes
14
Nov 30, 2020 05:21 PM
BOBSRED40
Nov 23, 2018 06:26 AM
Joe Avesyan
Nov 3, 2015 07:46 PM
trance957
Oct 11, 2012 04:04 PM
dannywb88
1G TSX Problems & Fixes
Jul 23, 2012 04:38 PM
