Switchback (turn signals) problems
Old Apr 15, 2015 | 04:16 PM
njrucci's Avatar
I put led switch backs for my front turn signals whitch are 1157 and I put a 50w resistor in and it works for a little and then the switch backs will shut off and on. idk if the resistor is not powerful enough or I need to get a smaller resistor??
Old Apr 15, 2015 | 04:20 PM
the wattage of the resistor usually doesn't matter.. it's more so the ohm's.
Also what brand are the switch backs? They could themselves be bad.
Have you tried troubleshooting by bypassing the resistor (aka not use them) It'll hyperblink but it can rule out if the bulb is bad.
Old Apr 15, 2015 | 04:23 PM
njrucci's Avatar
yes I tried taking out the resistor and them hyper blink like you said, but they work fine without the resistor. and I think they are called cree or something
Old Apr 15, 2015 | 04:24 PM
njrucci's Avatar
http://www.ebay.com/itm/251873493584?ru=http%3A%2F%2Fwww.ebay.com%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D251873493584%26_rdc%3D1
Old Apr 15, 2015 | 04:25 PM
njrucci's Avatar
http://www.ebay.com/itm/4-x-50W-6ohm-Load-Resistors-For-Hyper-Flash-Turn-Signal-Blink-Blinker-LED-Bulb-/251467551088?hash=item3a8ca25170&vxp=mtr
njrucci's Avatar
they are both the ones I used
Old Apr 15, 2015 | 04:47 PM
Have you considered this instead of load resistors? I've done it for myself and a few other members and it works great.
https://acurazine.com/forums/third-g...istors-815219/
If you want, i can do it for you as well
Old May 24, 2015 | 11:00 AM
al.c's Avatar
07 TL-S
I'm using the DIY method listed above and it's clean and away from the elements. Highly recommended.
baowheezy
Sep 22, 2015 09:03 PM
JnC
Sep 11, 2015 06:06 AM
theinsvnity
Sep 10, 2015 10:22 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
