Swapped 06 Auto trans wont shift past 1st gear
Old Oct 21, 2024 | 05:43 PM
NathanKrazy's Avatar
3rd Gear
Recently swapped transmission on a 06 auto. Everything’s back together no blinking drive light and no codes but car feels as though it’s in limp mode? Wont shift into second gear and revs high in first if it decides to move at all. Been at this for two weeks checked pressure switches and solenoids (not all just the two under starter, 3rd and 4th pressure switch, and the A&B solenoids on top. Kind of at a lost she has fluid have no idea where to go from here
Old Oct 23, 2024 | 12:39 AM
Drewskii18's Avatar
7th Gear
Where'd you get the transmission from- was it a remanufactured unit?
Old Oct 23, 2024 | 07:40 AM
3rd Gear
JDM NY warrantied to have 60-80k
Old Oct 23, 2024 | 11:53 AM
I see you state, in your initial post, that you 'checked' the solenoids & sensors.
Maybe try swapping the old factory trans' solenoids & sensors to the JDM trans. as a last ditch effort?
AT Sensor - Solenoid - 2006 Acura TL 4 Door BASE (NAVIGATION) KA 5AT
Old Oct 25, 2024 | 02:35 AM
Drewskii18's Avatar
7th Gear
What issues were you having before the transmission swap? I am having the same issues- 'feels as though it’s in limp mode? Wont shift into second gear and revs high in first if it decides to move at all.'
donkiboy
Apr 2, 2018 03:58 PM
corecardiacimaging
May 1, 2013 09:08 AM
yeedatoy
Dec 17, 2012 01:36 AM
Twotone
Jun 30, 2009 12:22 PM
ck123
1G TSX Problems & Fixes
17
Nov 12, 2007 10:31 AM
