Super fun new noise my car is making
Old May 22, 2012 | 06:42 PM
Mrtastygoody's Avatar
Level: Noob
When I go over bumps, I hear a clunking noise in the back. Sounds like a broken motor mount, but it's coming from the rear wheel area. WTF is it? Lol. I just put in my RSB the other day, could it not be tight enough? It's very irritating and I want it gone. Thanks!
Old May 22, 2012 | 07:23 PM
shenrie's Avatar
I would start with the rsb since that was the last area worked on. maybe you didnt tighten one of the bolts or something.
Old May 22, 2012 | 08:00 PM
oneglory's Avatar
check the rear endlinks.
Old May 23, 2012 | 02:04 AM
Level: Noob
I replaced the endlinks. =/ I got under it and tried to shake it all around and that thing was on there rock solid, like rocking the car back and forth a couple inches.
Old May 23, 2012 | 05:54 AM
oneglory's Avatar
not being a smart ass:
Make sure they weren't put on upside down (or backwards, whatever you want to call it).
Old May 23, 2012 | 05:56 AM
oneglory's Avatar
You won't be able to duplicate the noise by rocking it by hand...you can't put the same amount of pressure on the sway as the car can going into turns/bumps and whatnot.
Old May 23, 2012 | 07:49 AM
maharajamd's Avatar
End links.
Old May 23, 2012 | 07:53 AM
re-tighten everything.
it only makes sense, since you were last working on the RSB.
Old May 23, 2012 | 07:55 AM
maharajamd's Avatar
To go even further....it's probably the mount side of the end link that's not tight. I bet the RSB side is just fine.
Same thing happened to me not 2 months ago.
Old May 23, 2012 | 08:01 AM
to one up, mahar. I'll go in depth a little bit further.
check the mounts and tighten them up.
Old May 23, 2012 | 08:09 AM
maharajamd's Avatar
What mount Crabby McGee? The RSB bushing clamp/mounts or the actual lower suspension "mount". I refer to the latter.
If you didn't put in the RSB bushing mounts tight enough then I would be afraid.
Old May 23, 2012 | 08:12 AM
idunno wtf im talking about, i just wanted to Kanye you.
Old May 23, 2012 | 08:21 AM
maharajamd's Avatar
Old May 23, 2012 | 11:29 AM
mb190's Avatar
This happened on my other car. Either the springs broke off/just came off, one of the parking brake shoes was hanging & would clunk against the rotor when ever going over a bump.
Old May 26, 2012 | 07:46 PM
Level: Noob
Ill get under there tonite or tomorrow and try to tighten them up.
Old May 27, 2012 | 11:31 AM
lilsid112's Avatar
Did you lube your RSB bushings before clamping them down?
Old May 29, 2012 | 07:42 PM
honda_nut's Avatar
2024 Genesis G70 3.3T
can you please post the solution? i have had the same issue for a while and can't pin point the problem. i took it in to a suspension shop and even they couldn't find anything wrong. they said the struts might need replacing.
Old May 31, 2012 | 01:19 PM
Level: Noob
Went under there over the weekend, and OMG the nuts were so loose I could hand spin em. So I put an ungodly amount of Loctite on there and tightened them with a breaker bar. :P No noise now!!
Old May 31, 2012 | 01:59 PM
BrownBuck's Avatar
BrownBuck
Originally Posted by Maharajamd
HAHHAHAHAHA :gheyfight:
Old May 31, 2012 | 02:46 PM
swoosh's Avatar
takin care of Business in
OP any results/updates ???
Old May 31, 2012 | 09:51 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
See below.
Old Jun 1, 2012 | 11:19 AM
swoosh's Avatar
^^^ thanks man
Feb 25, 2020 09:57 AM
2012wagon
Sep 29, 2015 04:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
aces2412
3G MDX (2014-2020)
Sep 7, 2015 08:40 PM
dlknight
Sep 3, 2015 07:54 PM
