Subwoofer Rattle
Old Oct 30, 2010 | 07:06 PM
TLperfection's Avatar
Subwoofer Rattle
Hey guys
My 05 TL has a subwoofer rattle. It just developed.
I pulled the trunk liner down and the rattle is coming the from sub area. it's not by the rear vents. I also tried pushing down on subwoofer grill on the inside of the car but it's still making a noise. I have no idea what else could be causing the rattle.
Any ideas?
The rattle is VERY loud by the way. I cranked the volume up to 20 and it sounds like the sub is about to break
and yes I searched but couldn't find a solution!
Old Oct 31, 2010 | 01:41 PM
Update...
I found out that it's the sub vibrating against that plastic cage/holder that holds the sub. I was able to stick in some paper towels and MUCH better. However, it still rattles a bit.
Anyone know what I could use instead of paper towels that would stop some of the rattling?
Old Oct 31, 2010 | 02:40 PM
VQPower37's Avatar
maybe some sort of thick foam from an upholstery store?
Old Oct 31, 2010 | 09:52 PM
Thanks for the suggestion, i'll try looking into it!
Old Feb 14, 2013 | 11:10 AM
Mr.KansasCity816's Avatar
4th Gear
lots of good post for this problem..its a 5 min fix when you know what your going after
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/subwoofer-rattle-fix-713239/
https://acurazine.com/forums/showthread.php?t=614680
Old May 24, 2013 | 03:28 PM
dynodonkey's Avatar
https://acurazine.com/forums/showthread.php?t=713239
Soooo, from what i gather from the op, and from my experience, the rattle is coming from neither of these sources(which seem to be two fixes for the same problem). I have already fixed the rattle from the plastic J clip under the trunk light, which solved the problem for over a year. My rattle seems to be coming from the sub itself, or the general area of the sub. Any ideas? the dealer said it could be the clips holding the rear deck in place but it doesnt seem to be coming from that area.
Old May 24, 2013 | 03:42 PM
Acura604's Avatar
2024 RDX A SPEC
i had similar issue... one thing i did with one of my former TLs was stick velcro (soft side) along the area where the edge of the rear cover behind the rear seats meets the bottom of the rear windshield. that did an amazing job of reducing vibration style noises.
AndrewS
19
Mar 14, 2024 06:59 PM
kb1rl
Sep 30, 2015 10:17 AM
jmaxima03
Sep 27, 2015 10:22 AM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
3GTLOwns
Sep 9, 2015 09:51 PM
