Strong Vibrations during Hard Acceleration and Crusing
Old Mar 29, 2011 | 12:13 AM
Kstrick's Avatar
04 TL A Spec
Hey guys I am hoping you can help me.
I have strong vibration/shaking in my front end and steering wheel during hard acceleration and cruising past 60mph usually mellows out at 80+. Any Idea what it could be???
-04 TL Aspec (111k miles)
-lowered on Tein SS (stock struts)
-on staggered '19s
- Dynamic Damper has been installed, engine mounts, new sway bar link kit, lower transmission mount, new engine mounts
Thanks in advance guys. I was thinking a new front axle was needed, if you guys think that is the case could someone lead me in the right direction for all the parts that I need. Once again thanks!
Old Mar 30, 2011 | 01:46 PM
Kstrick's Avatar
04 TL A Spec
Any suggestions guys?
Old Mar 31, 2011 | 11:19 AM
invalidalias's Avatar
vibration
during acceleration would be worn out axels. I would try to balance the wheels/tires first. You may have bent wheels too.
Old Mar 31, 2011 | 12:34 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
1) search forums
2) check wheel balance, bent rim, alignment etc.
3) vibration with acceleration...sounds like it could be bad inner CV joint in which case just replace the axle. (been there, done that, no problems).
4) could be a few other things...as well.
Old Apr 1, 2011 | 02:25 PM
Vigor66's Avatar
Check your motor mounts
Old Apr 2, 2011 | 05:49 PM
Kstrick's Avatar
04 TL A Spec
^ engine mounts replaced have been replaced...thanks guys for the help
mlody
Dec 4, 2019 02:11 PM
joflewbyu2
Aug 18, 2019 10:38 PM
Oakroadsteve
Oct 28, 2015 10:28 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
joflewbyu2
Oct 8, 2015 11:16 AM
