Strange leak in back passenger seat
I have the oddest problem.
A couple years ago I started noticing that the back passenger side seat belt at the very bottom had some sort of crust of salt buildup on it. I just thought somebody must have gotten it wet. But it never actually went away after cleaning it.
This past weekend I had a family trip to Clevland from Chicago and on the way home it started raining. After a few hours my Dad said the seat is getting cold so he got up and his pants were soaked. The seat seams dry to the touch but I'm pretty sure the cushion has moisture in it.
Again in Chicago its raining so I went to my back seat and sure enough the bottom of the seatbelt is wet.
What could possibly cause this? I don;t see any vissible leaks, and it seams to be coming up into the seat.
Is the carpet wet in the back too? I have heard of people having their A/C drain tube drain into the back area because it's plugged up. Perhaps others can chime in here that had the issue.
Perhaps this thread will help:
https://acurazine.com/forums/3g-tl-2004-2008-93/might-new-one-3g-tl-garage-f-127-a-566392/
I can't imagine any correlation between the back seat and moisture unless it's getting in from the trunk seal. Inspect the top seal of the trunk and see if the carpet is moist. Doesn't sound good though.. I would take the bottom of the bench seat out and dry it out.. it will also give you a better view of what could be causing it.. I'd even run the hose over the car with the bench out and look for water seeping in.. strange.
was anybody sitting next to your dad trying to play a sick joke? how wet was the seat?
theres a TSB on this, I had my dealer perform it but I can't find it. there is a grommet under the car which has a leak, the dealer has to take it out, clean it and put it back with some sealant on it... I'll try to find it for you...
The seat is dry to the touch but oviously its wet.
that's crazy.. you know my seatbelts have moisture stains like that but unfortunately I have tan belts so they're very noticeable. I used Blue Magic to remove the stains and it has been successful but there is so much moisture that has stained the belts that it's difficult to fully treat and remove the stains. I just figured the previous owner dumped the car in a river
Thanks for finding this for us csmeance.. can't wait to find out more.
FOUND IT! page for of this service bulletin might help:
http://www.in.honda.com/Rjanisis/pubs/SN/B050400.PDF
HOME SWEET HOME....
man i thought i was the only one with this problem... im taking my car into the dealer wed mornin first thing... now i can stop banning people from my car. thought somebody or everyone for that matter was spilling water... the water damage messed up the rear seat pretty bad though, like the leather is hard with the cakey white powder hopefully some leather cleaner will fix that, and i gotta go find some stuff to get the cakey white residue off the seat belt...
being that my interior is blk, this sht is very noticeable and has been pissing me off for sometime now...
thanks CS for finding that bulletin.
Would the dealer still take of this even though I'm way out of warranty? Could there be any long term damage in the seats. It looks like and can do the seal myself. I'm more concerned with the damage it may have already caused.
I doubt the dealership will fix the problem although they're legally responsible since it is a design flaw that has caused damage and not simple wear & tear. Take it to them and find out.. otherwise.. try to amend the issue yourself. I don't think new seat belts would cost very much.. but nothing suprises me.. whatever you do.. don't pay them a dime for this issue.
