Stock sub blown, suggestions?
Title speaks for itslef. Around 1-7 vol level i hear rattles and it annoys the f out of me, what routes has anyone else taken. Whole new setup or just replace the stock sub with another stockie. Thnx in advance..
or buy an aftermarket upgraded sub that fits into the stock compartment.
the stock sub according to crutchfield is a: 40watt 8" woofer.
Grab yourself a nice aftermarket 8" woofer and install in place.
click here: 2004-08 Acura TL Car Audio Profile
Is the stock amplifier enough to power a higher RMS rated sub? If not, you're essentially going to get the same sound, maybe a little bit more out of it.
If the stock sub is rated at 40W, I can't imagine the factory amp, whether it's part of the head unit or not, to be able to push any more.
plus you could always splice in an amp for that sub
Read over stock replacement sub threads and you'll see a bunch of unhappy people. It's not worth throwing a sub in the stock location. It will never have much bass and the deck will rattle like crazy.
Search through this forum, several of us have some pretty nice systems. I have a sound quality setup and I run a pair of 16" subs infinite baffle so 90% of my trunk is still usable and it sounds absolutely amazing plus it will get very loud and low of needed.
On the other hand, if it is the sub, you can always go this route... mine wasnt blown, but I kept it for mids and added this
Rockford Fosgate Punch P300-12 Single 12" subwoofer enclosure with 300-watt amp at Crutchfield.com
most people recommend keeping the sub OEM and just stuff shop towels in the deck for the vibration?
ditto... a lot of the TLs have the rear deck rattle... make sure it is actually the speaker before you spend money.
Thanks.
saberlove
Mar 11, 2021 09:29 AM
Joseph Stansbury
34
Dec 4, 2015 01:57 PM
Inspire08
Oct 30, 2015 04:00 PM
