Steering Column rattle (when st wheel is locked into place only)
Old Jul 7, 2005 | 07:56 AM
Scott in Houston's Avatar
So, I have a small rattle when I go over bumps coming from the steering column.
The rattle goes away if I pull down the steering wheel adjustment lever and leave it down to where the steering wheel is movable. Once I lock it in place, the rattle returns.
Any ideas?
I'm going to take it to the dealer to fix, but would like to give them some ideas before they just start ripping things apart and causing more problems than they fix.
Thanks in advance.
PS. I'm not mad. I still love this car!
Old Jul 7, 2005 | 05:12 PM
Adobeman's Avatar
The DVD-A Script Guy
Sounds exactly like mine.
Check this https://acurazine.com/forums/showthr...ghlight=rattle
I think when you fully lock the adjusting lever there is less give (damping) in the column so you hear the rattle. I typically only here it on harsh roads when the interior is cold.
Old Jul 7, 2005 | 05:22 PM
Did yours get fixed by replacing these parts?
Old Jul 7, 2005 | 05:57 PM
Adobeman's Avatar
Haven't been to the dealer yet. Car's only got 1700 mi. If it gets bad enough I'll have it dealt with. If my suspicions are correct the cold winter weather in the NE will make it worse and then I'll deal with it.
Feb 25, 2020 09:57 AM
tman570
Jun 11, 2019 07:56 AM
spidermankb
Mar 5, 2019 11:34 AM
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
