Steering click-is this normal?
3G TL/2G MDX Owner
i just recently started getting a tick/click of sorts when i turn my steering wheel (its not an axle issue). it's similar to the sound of when the turn signal gets disengaged. its not loud and it does not affect the steering/turning of the car.
this started soon after my power steering fluid was replaced at the dealer (it was dirty) this week.
my car NEVER did this before. i have heard it in loaners and thought it was normal for the AT, but now since my car has this tick when i'm at a slow turn around corners or in parking lots, the noise is starting to bother me. seems t ohappen more when i turn Rt. vs Lt.
tell me this is NOT normal. and what could be the problem? and the consequences. thanks.
Chapter Leader (Houston)
Have you been driving the car since? I flushed my power steering last wknd and had some weird noises after. It went away the next day though. First, i'd pull the reservoir cap and look if there are any air bubbles in it.
3G TL/2G MDX Owner
i have driven the car since...about 4 times this week...and it ticks. doesn't happen everytime i turn, but enough for me to notice.
i did take a look into the PS reservoir...nothing out of the ordinary. they did fill it to just over the max fill line if that matters any.
Possibly something is worn in the turn signal assembly, certainly not normal, but here is a thread from the TSX Forum:
https://acurazine.com/forums/2g-tsx-problems-fixes-145/turning-steering-wheel-makes-clicking-noise-772945/
Daughter's Grand Cherokee developed this problem and the cancel cam ring needed replacement, but there was a TSB from Chrysler.
3G TL/2G MDX Owner
turbo-it happens with or without the turn signal being on. and why would it happen right after a flush?
i read that thread too, but wanted to know if 3G peeps had this issue. dont' we have a different mechanism for our PS? the newer acura's are electric aren't they?
I would also assume, whether mechanical or electric PS, the signal cam asembly would be of similar design.
Never had a TL column apart, so not certain as to the parts involved, and am on vacation in Florida so no FSM available.
3G TL/2G MDX Owner
ok apparently this is only happening when i have the turn signal on. never heard this noise before nonethless. so turbo...you're probably right. anyone else have a tick in their steering column WITH their turn signal on? and is this normal? my SA said it could be the cable reel, but they would need to hear it to confirm it. the part is less than $20. the labor will most likely be an arm and a leg.
6 yrs of ownership...never heard this before.
3G TL/2G MDX Owner
spoke with SA, says its most likely the cable reel in the steering wheel that is worn. the noise will only get worse with time. he said its nothing major, but just annoying with the click. so i'm going to monitor it and get it fixed when it comes time for the next oil change. if it gets really annoying...i'll get it taken care of sooner.
if anyone else has ideas feel free to chime in.
3G TL/2G MDX Owner
mine is actually coming from inside the car from the steering wheel area, like a plastic ticking noise.
Mine is from the inside as well
acuratl26
04-23-2020 07:30 PM
