Starting Problem
Old Mar 21, 2014 | 08:21 PM
JdmT's Avatar
5th Gear
Starting Problem
I just went out to start my car and the starter didn't even make a noise, it just kind of clicked and hummed. However all the interior lights and whatnot still came on. I popped the hood and readjusted the terminals and still nothing. I took my spare key because i misplaced the ones I had just tried to start it with and it started right up. I need to pick up my sister from the airport tonight and I'm concerned that maybe it is a battery problem and it will die on me. Any ideas as to what it is/ what i can do? Is it my key or something else?
Old Mar 21, 2014 | 08:34 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Could be your starter. Try whacking your starter a couple of times, next time it doesn't start.
Old Mar 22, 2014 | 10:24 AM
Sledneck's Avatar
I had the same problem and when it happends just move your shifter to reverse and after that put it on the Park(if you have a 5AT). The neutral safety switch cause this problem!
Sorry for my bad English, I am French
Old Mar 22, 2014 | 10:59 AM
skora89's Avatar
Also could be the solenoid.
Old Mar 26, 2014 | 04:27 PM
carz0159's Avatar
i think its the starter.
Old Mar 26, 2014 | 05:59 PM
grappletech's Avatar
I just replaced my starter. I have a manual I do not know if there are different part numbers but I went to the dealership.
Part #: 31200-RDB-A01RM
Old Mar 26, 2014 | 07:48 PM
Turbonut's Avatar
Using the spare key, just a coincidence, but next time it happens, turn on the lights and hit the starter, if lights dim considerably or go out, the battery, if not starter.
Get a mm and check voltage at battery, should be @12.4.
If it is the starter, one can usually get it to operate by turning the key back and forth many times, or hit the starter, but at some point it will not operate and leave you stranded.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
