Starter Grind
Starter Grind
Anyone experience this problem? Only when it's very cold 20 degrees F or lower. I start my car and the solenoid seems to stick for just a second and grind. Shut off car; try again- and it wont do it. My thoughts: starter solenoid sticking due to freezing temperatures;temporary delays the starter. Not a valid explanation because it should never do this; just curious if it has happened to anyone else?
So you think the starter drive gear is staying engaged with the flywheel after the engine is running for a second or two? If so you may have to remove the starter & clean & lube with a lighter lube where the starter gear slides on its shaft & any other links between the solenoid & the sliding drive gear. Don't rev the engine while the starter is is engaged to the engine(flywheel.)
im definitely experiencing the same starter issue you desired. difficulty starting the last 2 cold days (30s), grinding unnecessary, and multiple attempts before my tl starts. my 06 has 127k on it so its been through a lot. before i replace the starter, did you have any luck repairing and lubing the starter shaft?
Oh wow, two year old thread lol.
Mike Pilipenko
Mar 26, 2024 09:21 PM
Jul 16, 2017 07:33 AM
