Squealing brakes
Old May 9, 2018 | 06:43 PM
Joecop67's Avatar
Squealing brakes
My brakes squeal only when backing up and only after sitting overnight. I plan on spraying wd40 on the calipers and rotors through the spokes of the factory wheels.
I will do 1 wheel at a time, so that when the squealing stops, I'll know which one it is. Sound feasible?
Btw, is there a belt in my brakes?
Old May 9, 2018 | 08:13 PM
b15's Avatar
b15
Missing the facebook group?
but yes there is a belt. Should only use genuine Acura NSX lube though.
Old May 9, 2018 | 08:14 PM
Joecop67's Avatar
Old May 9, 2018 | 08:57 PM
stevemk07's Avatar
I had this problem not long ago. Replaced calipers pads rotors axles ball joints, steering rack..... Finally changed the belt. Squeel been gone since.
Old May 9, 2018 | 09:02 PM
Joecop67's Avatar
Maybe I should try belt dressing then.
Old May 9, 2018 | 09:04 PM
Joecop67's Avatar
In all seriousness, I bought some brake grease. Going to do the rears first and hoping that fixes it. Reading the stories here about stripping the aluminum threads on the Brembos scares me. Lol
Old May 9, 2018 | 09:13 PM
Jackass's Avatar
You don't have to remove those bolts to grease the back of the pads. Just pull the pins and the pads will slide out. You only have to touch those bolts if you are replacing the rotor.
Old May 10, 2018 | 04:26 AM
Joecop67's Avatar
Great, thanks.
Old May 10, 2018 | 01:12 PM
Like dude, you read that thread to I see, lol.
Old May 10, 2018 | 01:42 PM
Joecop67's Avatar
lol, it can’t have been real.
Old May 10, 2018 | 01:47 PM
my brakes used to squeal on backing up and it was because my brake drum shoes needed adjustment. I bought new ones thinking it needed replacement but took them all apart and they looked mint. tightened it all back, re-calibrated the star nut to the proper turns, checked the e brake lever in cabin to ensure it was at the proper number of clicks and voila, no more squealing.
Spoiler
Hope that helps!
Old May 10, 2018 | 02:46 PM
BreezyTL's Avatar
Literally spit soda all over my desk!
Old May 10, 2018 | 02:47 PM
BreezyTL's Avatar
Didn't see who the OP was but you almost had a reply from me, but them I saw it was you and thought. You sonna bitch, you almost had an epic reply coming your way!
Old May 10, 2018 | 04:00 PM
Joecop67's Avatar
I would have liked to have seen it.
Old May 10, 2018 | 04:05 PM
Joecop67's Avatar
Thoiboi, I don't think it's the e-brakes shoes. The e-brake had to be pulled up almost all the way to keep the car from rolling down the driveway in neutral and it has squealed since I got it.
When I swapped the 08 display in a few weeks ago I tightened up the adjustment nut under the cup holder so it would grab a little bit earlier.
The lady I bought he car from in December had the rear brakes doe in the fall and one caliper replaced. He probably didn't use an grease.
Heck, in 34 years of doing my brakes, I've never used the grease. Never had any brakes squeal so I figured it was marketing from Big Grease. Lol
FZ427
1G TSX Problems & Fixes
Mar 7, 2022 04:57 PM
rxrxrx
Nov 3, 2006 02:10 PM
Skyhigh
1G TL (1996-1998)
Apr 30, 2003 08:34 AM
Zapata
Jan 10, 2002 05:19 PM
