Spark plugs
Old May 19, 2013 | 08:45 AM
Mahmoud Hussein Moussa's Avatar
Spark plugs
04 acura Tl just changed spark plugs form stock to NGK LASER IRIDIUM Spark Plug IZFR6K-1. but it still miss fire what could be wrong? does NGK laser iridium they come Gaped or i need to get it Gapped?
thank you
Old May 19, 2013 | 09:05 AM
I hate cars's Avatar
Is your car a 6mt?
Old May 19, 2013 | 10:26 AM
BukvaMan's Avatar
Ignition coil possibly
Old May 19, 2013 | 12:36 PM
TheLowLife's Avatar
I would start by gapping them correctly..
Old May 19, 2013 | 01:04 PM
it is base model? idk whats 6mt.... to gap them i need buy that thing for it from store such as auto zone?
Old May 19, 2013 | 01:38 PM
Iridiums should always come pre gapped. They're very easy to damage when you gap them. If you're worried about it, buy a feeler gauge to check the gap but don't try to change the gap without the tool. With normal plugs I'll use a flat screwdriver but not with the iridiums.
For a new spark plug to cause a misfire the gap would have to be closed down completely, no gap or a huge gap, both would be easily visible. Is your TL a manual transmission and have you mis shifted or over revved it at all? A miss can be cause from several things but knowing if you have a manual transmission will point you in the right direction, where to start.
Old May 19, 2013 | 02:05 PM
nfnsquared's Avatar
The IZFR6K-11 is the stock plug. Not sure what you had in there before (unless it was the Denso stock plug, but never heard of a car coming from the factory with Denso installed).
but it still miss fire what could be wrong? does NGK laser iridium they come Gaped or i need to get it Gapped?thank you
The NGK's come pre-gapped at 0.044" which technically is outside of spec (0.039" - 0.043"), but in reality is not an issue. You shouldn't have to change the gap.
Old May 19, 2013 | 04:20 PM
if the gaping is right so why would new spark plugs still miss fire? when i took out the old ones they were rusty
Old May 19, 2013 | 04:33 PM
ionojimbo's Avatar
maybe it is your coil?
Im not sure if only TLs that have a navi tell you this but when i had a misfire, my engine light flashes and my navi screen tells me the error code. turns out it was cylinder one and when i checked the coil was the problem.
for my situation it turned out the coil short circuited somehow and exploded and melted.
in terms of your spark plugs the NGKs you installed should have come factory already.
Old May 19, 2013 | 09:03 PM
colindunn's Avatar
Make sure the plug is on the coil all they way. Did my plugs today as well and one of my coils wasn't plugged in all the way. Otherwise everything went fine.
Old May 19, 2013 | 09:15 PM
I'm guessing from the OP that the misfire was there before changing plugs and he changed the plugs in hope if fixing the misfire.
A little more detail is needed in addition to what I've already asked. Is the misfire only at idle? Hot or cold make a difference?
Old May 20, 2013 | 05:58 AM
Turbonut's Avatar
Engine light on-Code?
Old May 20, 2013 | 08:15 AM
Yeah the engine check light is on.... it was flashing like crazy on and off
Old May 20, 2013 | 08:16 AM
when it gets hotter is idel better at like 850
Old May 20, 2013 | 08:19 AM
you're dancing around the questions that need to be answered.
Please help us, help you, by answering some of the important questions.
is your car automatic or manual?
were you replacing the spark plugs in hopes of getting rid of the misfire?
Old May 20, 2013 | 08:55 AM
Project_CLean's Avatar
MMkay.
Also, who replaced the plugs? What is the DTC (Diagnostic Trouble Code)? Did you notice any oil on the coils or on the old plugs? An engine misfire could be anything from a plug to compression loss or fuel pressure issues.
Old May 20, 2013 | 10:15 AM
it is automatic i never see no oil leaks the coils were fine but old spark plugs were rusty when i try take them out it was skeeeking like crazy . i changed them my self " didn't not put them too tight ".. i took video starting car and.. quick look but i hope it helps .. i haven't taken it to auto zone or something to see what code i will get .
Old May 20, 2013 | 02:32 PM
nfnsquared's Avatar
.... old spark plugs were rusty when i try take them out....
Where was this "rust"? A "corona" on the porcelain is normal...
it was skeeeking like crazy .....
Huh?
Get the code/s read.
Old May 20, 2013 | 04:22 PM
Will Y.'s Avatar
Registered but harmless
Huh?
My guess is that OP meant "squeeking" or a metallic squealing as the plug was loosened.
The code will give everyone a much better idea of the potential issue(s).
Old May 20, 2013 | 07:19 PM
dannyz's Avatar
TLicious Type S
Wow, that video was better then Space Mountain! I vomited half way through... What was the question again?...
Old May 21, 2013 | 02:00 PM
Mrtastygoody's Avatar
Level: Noob
Jesus Christ, that video made me so dizzy. I had to turn my laptop upside down lol
Old May 21, 2013 | 11:10 PM
MEKO's Avatar
Shaking?
Old May 22, 2013 | 07:29 AM
MMkay.
^ Meko,he means squeaking. Imagine a rusty bolt slowly coming out of its threads, that "skeeking" is the noise he heard & described when turning the spark plug.Kind of like metal on metal friction.
I'm not sure where this thread is going, soooo
Old May 22, 2013 | 08:21 AM
Nowhere lol.
Old May 22, 2013 | 09:14 PM
dannyz's Avatar
TLicious Type S
Use nothing but stock spark plugs.
Close thread!
Old May 22, 2013 | 09:50 PM
Lol. I've always used "regular" $1-$2 plugs in the TL. No need for iridium as long as you change every 40-60k which I would do anyway just to keep an eye on what's going on in each cylinder. I know #3 is very, very, slightly leaner than the rest and the other 5 are identical. I'll know if that changes when I change the plugs and it can be an early indicator of fuel system issues or weak compression, etc. I'm probably the only person on this forum to use regular plugs but there's nothing special about the engine or ignition system that would make it "require" iridiums for anything besides long life. My last plug change was about $15 total. Obviously stock plugs are superior in the longevity department and as long as you're not completely OCD like me they're a safe choice.
Old May 23, 2013 | 07:42 AM
MMkay.
^ IHC, do you use plugs with the same heat range at least? I've only owned Japanese cars, and always try to use OEM spec plugs because of this. I also bought a honda accord that someone had replaced the plugs with Bosch Platinums, and experienced misfires and shitty acceleration.Threw in a set of NGK platinums at 2.99 ea. and ran like a charm.Maybe it was the car, but that was enough to change my perspective on plugs.
Old May 23, 2013 | 08:23 AM
Yeah, way back when I was trying to find the pinging problem I switched to some platinum one step colder with no problems. Due to laziness I left them in for 40k. I still have those if anyone wants pictures. Since then I've been using regular plugs in the stock heat range.
The iridiums are going to maintain the same gap over 100k while the regular plugs are going to open up over time but I've never experienced the slightest problems with regular plugs whether its cold start, idle, normal driving, or full throttle. I'm not afraid to spend money on a good product like my lubricants but I can't see an advantage to iridiums at my change interval. I'm not telling anyone to use regular plugs but over nearly 100k miles on regular plugs, not problems.
Old May 23, 2013 | 08:45 AM
MMkay.
Ahh, I see. Makes sense.
Mike734
Dec 10, 2021 01:25 PM
acuratl26
Apr 23, 2020 07:30 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
