Solenoid issue
Old Aug 10, 2019 | 04:26 PM
Garret428's Avatar
9th Gear
Solenoid issue
So driving down the road in gear I give in gas and I have no power and acts like I am in neutral. Then the car shudders acting like it’s trying to find what gear it needs to be in. But when I pull over disconnect the battery my car will run fine for a bit until I give some gas then I will be driving then no power and act like I’m in neutral and can’t find a gear to be in. I got a road trip Monday and I need something! Just did transmission oil and filter, checked shift solenoid and cleaned it. Putting power to the solenoid they work but I’m not sure if are bad because my car would run fine then do that thing so plan on switching them out but if anybody knows anything let me know!!
Old Aug 10, 2019 | 04:58 PM
ttribe's Avatar
Year, make and model of your car?
Old Aug 10, 2019 | 05:06 PM
Garret428's Avatar
9th Gear
Acura TL 2004
Old Aug 10, 2019 | 09:11 PM
ttribe's Avatar
MODERATOR NOTE: Thread moved to model specific forum.
Old Aug 13, 2019 | 12:14 AM
csmeance's Avatar
check your fluid level and make sure it's right! You could have too little fluid, or your trans is failing. Is the D light on the dashboard in the RPM gauge blinking? Did you put the shift solenoids back in the right spots?
Old Aug 13, 2019 | 07:17 AM
t-rd's Avatar
Does it drive fine if you shift and start in D3? Or manually shift?
Acuralin
Jul 23, 2015 08:20 PM
collegeguy60
Apr 28, 2013 09:30 PM
ed_423
May 25, 2010 01:18 PM
CDFixer
4G TL Problems & Fixes
Jan 28, 2010 12:06 AM
ucla107
Jul 5, 2001 05:08 PM
