Small leak.
Old Feb 11, 2012 | 10:22 PM
knoxtl's Avatar
Small leak.
Small leak, coming from engine not took pics but don't know how to post. help?
Old Feb 11, 2012 | 10:30 PM
ggesq's Avatar
I use photobucket. Go to their site. Sign up. Upload the pics. Copy & paste the img code here.
Old Feb 11, 2012 | 10:35 PM
knoxtl's Avatar
uploading right now. I really hope its not serious.
Old Feb 11, 2012 | 10:43 PM
knoxtl's Avatar
Old Feb 11, 2012 | 10:47 PM
knoxtl's Avatar
Also do you think i will be able to fix this myself?
Old Feb 11, 2012 | 11:12 PM
knoxtl's Avatar
someone please help
Old Feb 12, 2012 | 12:13 AM
xander569's Avatar
My First Acura
Its late, more people will answer tomorrow. Is it leaking under the car when youre parked?
Old Feb 12, 2012 | 12:14 AM
Hi speed's Avatar
runnin a little boost
Looks like a valve cover gasket leak. Should be easy to fix if you want to do it.
Old Feb 12, 2012 | 12:24 AM
knoxtl's Avatar
no no oil under car at all. would i just buy the 35 dollar gasket kit? Do you think i should gunk foam clean it off and then inspect it again to pinpoint or does this look like valve cover gasket leak for sure..?
Old Feb 12, 2012 | 10:54 AM
ez12a's Avatar
the overexplainer
you can clean it if you want to confirm, but really, the only other oily substance that goes around that area would be from the P/S pump..but that's not really near where that grime is. Since the grime is so far up on the engine it can only be from so many places.
Old Feb 12, 2012 | 01:15 PM
Bitter Melon's Avatar
Make sure the seals that sit around the spark plug holes sit properly when you put the valve cover back on.
Old Feb 12, 2012 | 01:21 PM
TheDingo's Avatar
Resident Dingo
^ +1
If you do put a valve cover gasket on it, BUY THE PARTS FROM ACURA. This is one of those parts that you should get OEM.
Get the whole kit <$50. This will cover the valve cover gasket, the holes around the spark plugs etc.
Old Feb 12, 2012 | 02:40 PM
knoxtl's Avatar
Thanks i really appreciate the help. i may do a writeup on this, while I'm at it I'm going also replace the spark plugs and port and polish the intake manifold. Should i also do a valve adjustment. car has 127,000 miles on it just bought it about 1 month ago. Its a 2006 tl5at.
Old Feb 12, 2012 | 03:23 PM
ohsixMTee's Avatar
Early Shifter
Another vote for valve cover gasket.
Not sure on the valve adjustment, I'd say if it doesn't tick/tap and runs good to leave good alone. I'm sure it couldn't hurt though if done correctly....
Old Feb 12, 2012 | 03:31 PM
knoxtl's Avatar
can i do the porting and polish job myself i have found a thread about pNp but not a diy. Anyone have a link to the right thread or know how to do this.?
Old Feb 12, 2012 | 05:12 PM
TheDingo's Avatar
Resident Dingo
If you have to ask about if you should do a port & polish yourself, you probably shouldn't DIY.
If the valves are ticking, give them a once over.
Old Feb 12, 2012 | 05:42 PM
knoxtl's Avatar
i mean it doesn't seem too difficult, so i am not allowed to do it if i have to ask if this is something that i would be able to do in my garage? whats the reasoning behind that? Can you do it?
Old Feb 12, 2012 | 06:02 PM
TheDingo's Avatar
Resident Dingo
Search the forum and find the DIY. I'll allow that.
Old Feb 12, 2012 | 06:25 PM
knoxtl's Avatar
lol, i have been looking at them i can't find a diy tho. Also reading how some are trying to put a 4g TB on. i am pretty overwhellmed with pages and pages of debating, can you post a link to a diy?
tsx_boy
Dec 13, 2019 08:33 PM
lanechanger
Oct 13, 2015 10:56 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
ceb
ILX
Sep 27, 2015 10:56 AM
joflewbyu2
Sep 23, 2015 11:16 PM
