Small issue
Old Feb 13, 2011 | 11:41 AM
absolute_jdm's Avatar
Small issue
so i just installed my TEIN basic's on my 08 TL-S .. after doing so when i drive at bout 25mph the car slightly vibrates and then goes away past 25mph.. is there a reason why this is happening? anybody out there have the same issue? how do i fix it?
Old Feb 14, 2011 | 06:05 PM
NO HELP!?!?!? ahahah..
Old Feb 14, 2011 | 07:24 PM
Turbonut's Avatar
When suspension dropped, this changes the angle of the front axles and vibration can be noticed.
Old Feb 15, 2011 | 02:29 AM
D-DUBZ TL's Avatar
++1 whenever u lower ur car, alot of things can feel differents, vibration, squeaky noise wen turning etc. Since u jus installed them get a alignment asap, if u don't ur camber, toe, caster can go off balance causing these things. If not go back n check all the suspension n see if there is a loose bolt or a bolt that u may hav forgot to put back!!
Old Feb 15, 2011 | 07:39 PM
ChucksCL-S's Avatar
Might need an alignment in the front and Ingalls camber kit in the rear to straighten things up. Also, don't go too low......
Old Feb 15, 2011 | 10:24 PM
thanks everyone.. but i went back to check everythin and everythings tightened and no bolts were missin cause it was a pretty easy install.. i believe an alignment will do the trick. Oh and new tires! lol.
snorf
Nov 4, 2019 06:44 AM
mugen_kid
Nov 13, 2015 10:38 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
01CLOwner
Oct 9, 2015 01:07 PM
Billu99tl
Sep 13, 2015 11:30 AM
