Small issue
Small issue
so i just installed my TEIN basic's on my 08 TL-S .. after doing so when i drive at bout 25mph the car slightly vibrates and then goes away past 25mph.. is there a reason why this is happening? anybody out there have the same issue? how do i fix it?
++1 whenever u lower ur car, alot of things can feel differents, vibration, squeaky noise wen turning etc. Since u jus installed them get a alignment asap, if u don't ur camber, toe, caster can go off balance causing these things. If not go back n check all the suspension n see if there is a loose bolt or a bolt that u may hav forgot to put back!!
thanks everyone.. but i went back to check everythin and everythings tightened and no bolts were missin cause it was a pretty easy install.. i believe an alignment will do the trick. Oh and new tires! lol.
snorf
11-04-2019 06:44 AM
mugen_kid
11-13-2015 10:38 PM
CheeseyPoofs McNut
10-11-2015 11:25 AM
Billu99tl
09-13-2015 11:30 AM
