Small coolant leak on driver side
Old Apr 1, 2023 | 05:48 PM
Mpham626's Avatar
4th Gear
I’m seeing a small coolant leak underneath the driver side. I checked under the hood to see where the leak comes from but I couldn’t find or see anything. Anyone know where this leak comes from? Thank you!
Old Apr 4, 2023 | 12:21 PM
twokexlv6coupe's Avatar
My guess is, it's coming from the cooling system.
A picture of the puddle on the ground is useless. Peak around under the hood some more, you should find it.
The radiator hoses connect to the engine on the drivers side. If it were me, that's where I'd start looking.
Old Apr 4, 2023 | 01:22 PM
Igotissues666's Avatar
I ain't right In the head
You just have to reach in (starting from the highest point that the leak would likely start, and work your way down.) Use a paper towel so that it's really easy to see if there are wet spots where you're feeling around.
Feel where the radiator hoses connect on both sides. Then, where the heater hoses connect on both sides. Then underneath the radiator. And just continue to work your way down. Water doesn't always leak straight down. It might take an easy, crooked pathway that's a foot or more to the side of the leak.
mvidal6
ILX
Jul 3, 2015 11:42 AM
GoldenBoyGus
May 7, 2015 09:14 PM
BoriTL
May 20, 2014 10:16 AM
kikimimi
Dec 25, 2012 04:09 PM
