Slight gas pedal vibration at high speed
Hello, I have an 06 Acura TL with 164k miles. Recently I have been feeling a slight vibration at the pedal only between 60 to 80mph. Car wheels have been balanced (hunter road force) and aligned. Some more info that might help with this but not sure if related. Car also has aftermarket motor mounts, I do have a vibration at idle but I dont mind it but not sure if it is related. Any help or routing me in the right direction would be much appreciated. Thanks...
edit: Axles are stock original but visually seem fine. I do have warped warped rotors which I am aware of but again not sure if this can be related.
so the car is smooth, and the steering wheel is smooth?
You ONLY feel it through the gas pedal? At what speed? 120?
I don't know, man...you can drive yourself nuts chasing that sort of thing.
Avoid doing what causes it. I'm sure rotors and axles could be...I had a weird
wiggle feeling when accelerating on my TL at 34K miles back in the day...ended
up being the axles didn't like the new angle after I lowered the car. Then
I chased a high speed vibration all over town...ended up being a bad balance
machine and tech...
So many variables. Just don't go that speed.
machine and tech...
machine and tech...
machine and tech...
I never replaced them, will look into replacing the trans mounts.
Audioholics
Jul 18, 2011 12:51 PM
eagles7439
Oct 10, 2008 12:41 PM
tdoh
Oct 6, 2001 11:14 AM
