Signs of a Transmission problem???
Old Feb 13, 2015 | 08:21 AM
coykiam's Avatar
Unhappy Signs of a Transmission problem???
Not sure where to post this but.....
My 2006 5AT TL with 99,600 miles on it just suddenly started showing the following symptoms:
1) When starting in the morning the car shifting goes from Park to Reverse then to Drive as I'm backing up the driveway. But from Reverse to Drive it would take 5-10 seconds before it engages. Then it ran fine when it would warm up.
2) Recently even when the car is warm (not sure if its due to NY's very frigid temperatures) but when it's on Drive I can feel the car shift from 1st to 2nd then it revs all the way to 4,000 to 5,000 before it engages to 3rd.
3) While on the highway or local streets from a stop it feels like it the car rev's as if it's in Neutral before it engages on any gear.
About a month ago I replaced the 3rd and 4th gear switches, if that matters. And also "service B14 due soon" just popped up. Will a transmission drain and fill fix the shifting issues???? Since I'm planning to have the service B14 done at the stealership.
Thanks all.
Old Feb 13, 2015 | 09:54 AM
AMTMJ's Avatar
Check your transmission fluid level if you haven't already (check it per the manual - basically with engine completely warmed up and within 1-2 minutes after engine is shut off).
Thanks all.
Old Feb 13, 2015 | 12:58 PM
coykiam's Avatar
Currently it's at the dealer for the B14 service and having the fluid drain/fill. Hoping the drain and fill will fix it since I did not get any error codes.
Old Feb 13, 2015 | 01:46 PM
aIRpeACE's Avatar
i am not sure if it will fix/eliminate the problem. but definitely do a drain/fill ASAP. Drive a week or two then do another drain and fill.
Old Feb 18, 2015 | 08:39 AM
coykiam's Avatar
update, car is currently at the dealer getting another tranny
Old Feb 18, 2015 | 05:38 PM
SUPERCAPRICORN's Avatar
my car started doing the exact same thing 2 days ago starting with the delay going into drive and reverse then the slipping and downshifting. what did the dealer find cause obviously you tranny is being replaced. i have an 05 TL auto with 101,000 miles.
Old Feb 19, 2015 | 08:00 AM
coykiam's Avatar
Apparently according to the dealer the 1x3 drain/fill thinned out the fluid in the tranny and caused the slipping.
I just got the car back and it is running like a champ again.
Old Feb 19, 2015 | 11:42 AM
aIRpeACE's Avatar
how much did the dealer charge you to replace the tranny?
dealers and most shops prefer to replace the defective parts instead of fixing it.
Old Feb 19, 2015 | 06:10 PM
that reason by the dealer doesn't make sense since fresh tranny fluid is slightly thicker. anyway how much did you pay for the job. going to the dealer in the morning to have it inspected and diagnosed.
Old Feb 19, 2015 | 06:17 PM
guitarplayer16's Avatar
I'll add to a similar story.
My car was driving PERFECTLY fine. Shifts perfect, everything. Transmission fluid was changed in May 2013, and pressure switches also.
Then came May 2014.
I did a drain and refill, and IMMEDIATELY after the drive, my transmission slips (flares) going from 3rd to 4th gear.
Even though it's not my first time, I didn't trust my job, so I went to a Honda/Acura specialist shop and had them do the drain/refill. Same symptoms.
It's now Feb 2015, and I am still driving it the same.
If I let off the gas (almost completely) when I feel like it needs to shift to 4th gear, it does not flare and slips right into 4th gear.
Now if I keep holding the acceleration, when it needs to shift, it will flare.
This is the one reason why only I will drive my car, no one else can.
Old Feb 20, 2015 | 01:07 AM
YeuEmMaiMai's Avatar
have you tried removing the solenoid pack and cleaning the screens up?
Old Feb 20, 2015 | 02:15 AM
pnoi521's Avatar
Registered TL Owner
smh My car had those same exact symptoms before the tranny went out in Jan '14. Only had 102,000 miles on it. Seems like your car, super's, and mine were all in the same mileage range when our transmissions went out.
Old Feb 20, 2015 | 10:06 AM
coykiam's Avatar
My guess is the Tranny was on it's way out and the drain/fill accelerated the slippage due to fresh fluids. It was a hefty bill but Acura and the dealer helped me with the bill since they were able to retrieve service records of the car. And since I didn't want any monthly car payments for a new one, it seems cheaper to pay the bill.
Then came May 2014.
Wow! I'm surprised it lasted that long with that kind of shifting. How is it in cold mornings? Mine was getting worst as the temperature gets colder. And I was doing the same with what you're doing (letting off the gas then it shifts) But it just got worst.
Old Feb 24, 2015 | 09:01 AM
Cold mornings have been the same, only slightly worse; shifts take a long time, and I get the flaring if I don't ease off the gas between 3rd to 4th
Old Feb 25, 2015 | 08:01 PM
Guys need help asap. Car is currently at dealer and there saying i need a new tranny. Quoted me $5,400 out the door. I think that is the highest number i ever read on these forums. Spoke to service manager and asked for goodwill and he said only 5%. I said no way. He says to call him in the morning and well see where we are at. i think they are jerking me. Need opinions and advice. Also a contact number to ACURA corporate. Thanks.
Old Feb 25, 2015 | 09:08 PM
vietxquangstah's Avatar
You can get it rebuilt for 50% of that price.
Old Feb 25, 2015 | 09:17 PM
Exactly but where. Im in NJ. Car currently at the dealer and is not drivable. Not sure how to proceed.
Old Feb 25, 2015 | 09:48 PM
MarcDavidoff's Avatar
Can you do the AV6 swap like the 2nd gens?
Old Feb 25, 2015 | 11:12 PM
Yes, you can use 06/07 V6 Honda transmission, much cheaper too.
Old Feb 26, 2015 | 11:35 AM
What does av6 swap mean?
Old Feb 26, 2015 | 11:41 AM
Swap a honda transmission.
Old Feb 26, 2015 | 12:11 PM
polobunny's Avatar
Registered Bunny
Accord V6 swap. Referring to the transmission as guitarplayer mentioned.
Old Feb 26, 2015 | 06:36 PM
OP - Here is the thread you probably want to read
https://acurazine.com/forums/second-...n-swap-905115/
pstomps
Feb 20, 2017 03:29 AM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
