Side view mirrors stick & pop when rotating down
Old May 21, 2008 | 06:12 PM
SRT-11's Avatar
Quiet, Rika Neenja!
They work, but when they rotate down they seem labored and they pop and stick a bit. how does one go about removing the mirror glass? also, is there a track or gear I could lubricate that would help resolve this issue?
thanks all!!!
Old May 22, 2008 | 03:01 PM
BLACKURA_NY's Avatar
I have car ADD
mine too.... my 06 TL it was smooth, but my type-s, i noticed they seem to "struggle" when titlting.. they shake, pop & make louder noises than usual
Old May 22, 2008 | 05:45 PM
SRT-11's Avatar
Quiet, Rika Neenja!
so.... how to fix?
Old May 22, 2008 | 08:17 PM
csmeance's Avatar
Originally Posted by SRT-11
so.... how to fix?
Take it to acura, they will either replace the motors or try to lube up the motors.
Old May 22, 2008 | 09:34 PM
SRT-11's Avatar
Quiet, Rika Neenja!
yep, my warranty was up a few months back and the dealers in my area are douchebags and I have to drive 45 minutes to get to either one of them. so how do I fix? better yet, how do I remove the mirror glass without breaking it? I'll figure out how to fix the rest and do a how-to!
Old May 23, 2008 | 06:54 AM
baby_igor's Avatar
I have manually moved the windows back and forth and that seems to loosen then up for awhile.
Old May 23, 2008 | 07:18 AM
DMZ's Avatar
DMZ
Head a da Family
I've had both side mirrors replaced under warranty for this very problem. The passenger's side last week and the driver's side last year. If you're still within your warranty period, take your car in and get new ones installed. Or, if you're beyond warranty, take this opportunity to upgrade the mirrors to the '07/8's with the turn signals.
Old May 23, 2008 | 12:18 PM
jwclements1's Avatar
I had that problem on my '04s right mirror. At 75k, I don't have a warranty so the dealer wanted $275 to replace it. I bought a can of silicone spray lube w/the little red straw and moved the mirror up and down spraying inside. That was two months ago and it still works normally.
Old May 23, 2008 | 12:35 PM
1StGenCL's Avatar
958 & 991
same here, cracks and pops
Old May 23, 2008 | 08:26 PM
kipwa007's Avatar
Same problem, was going to take it in the next time I need an oil change. Started to do so about a week ago at 15k.
Old May 23, 2008 | 09:21 PM
nick04tl's Avatar
just manually push the glass all the way up and down and side to side.
Old May 26, 2008 | 05:30 AM
SRT-11's Avatar
Quiet, Rika Neenja!
k well i'll post a DIY if someone can tell me how to remove the glass w/o breaking it!
Old May 27, 2008 | 11:28 AM
djbonsu's Avatar
"Like None Other"
same problem here...i actually just started doing it. im gonna take it in during my nxt oil change to have them fix it as i do still have the extended warranty.
Old May 27, 2008 | 12:22 PM
SRT-11's Avatar
Quiet, Rika Neenja!
they'll probably fix it under extended warranty, after you pay the deductible of "a whole bunch"
if someone can post the manual page that has the mirror glass removal instructions I'll do a how to to fix this!
BoricuaTL
Apr 8, 2016 01:08 PM
Rocktman1
Oct 31, 2015 02:33 PM
sockr1
Oct 1, 2015 01:31 AM
Sep 17, 2015 10:16 AM
dre707
Sep 8, 2015 08:32 PM
