Side View Mirrors--Problem
Old Feb 18, 2008 | 04:18 PM
Crissy78's Avatar
My side view mirrors will no long adjust down for backing up. I put the car from reverse to drive several times but nothing happens. I just noticed this today as I left work. Has anyone else had this problem? Is there anything else I should try before taking it to the service department?
Old Feb 18, 2008 | 05:18 PM
Bearcat94's Avatar
AZ Community Team
Make sure the mirror selector switch is either "Left" or "Right" - that determines which mirror tilts down. If the switch is in the center, neither mirror tilts.
Old Feb 18, 2008 | 06:35 PM
BLACKURA_NY's Avatar
I have car ADD
^basically, or a fuse
do your mirror heaters turn on and off? (lil yellow light)
Old Feb 18, 2008 | 07:35 PM
Crissy78's Avatar
yeah everything else seems to be working correctly, they just won't move now. i just noticed it today. i guess i'll get them to check it out when i go for an oil change.
Old Feb 19, 2008 | 04:26 PM
rajunwild's Avatar
2006 Acura TL
I have the same problem on 06 TL. I have made sure that the switch is correct and sometimes I have to place the vehicle in park and then in reverse for the mirros to work. And sometimes when they do work, they do it in a sloppy, unsmooth manner.
Old Mar 6, 2008 | 06:58 PM
DiZlAoSbOiSoFlY's Avatar
Rock Chalk JayhawkZ
yea mine does not work as of right now either....i tried switching it to left and right and they still wont go down....should I bring in to the dealer to have them look at it?
Old Mar 6, 2008 | 07:09 PM
722ish's Avatar
71Q
the dealer replaced both my mirrors, housings and all... .somehow, it did fix the problem.
Old Mar 6, 2008 | 11:41 PM
Rock Chalk JayhawkZ
I guess I'll make an appointment with the dealership and see if they can replace mine...
Old Mar 7, 2008 | 08:50 AM
chill_dog's Avatar
Oderint dum metuant.
I had the same problem...it's a dealer/warranty fix. Something is bad with a motor or switch (I forget what). My left one was bad, but Hendrick tested the right one while they had it and said it was bad, too. The replaced both under warranty.
Old Mar 8, 2008 | 05:34 PM
Rock Chalk JayhawkZ
Thanks chill_dog..made an appt for wednesday so lets see what they say!!
Old Mar 10, 2008 | 09:44 PM
Lane21's Avatar
Had this same problem in my 04 TL. It was also accompanied by my windshield washer motor not working. The dealer replaced a fuse and it fixed both problems.
Old Mar 11, 2008 | 10:40 AM
rajunwild's Avatar
2006 Acura TL
I just had mine into the dealer yesterday for the issue.....First they say that they cannot replicate, Then they give some crap that they use a trick where they manually adjust the mirror down to like 2-3 clicks and that will readjust it and fix the issue. Either way the issue is fixed, and I have it written that I brought it in for this. When I told them about Acurazine, he didn't want to hear it and gave me an attitude. I wanted to b*tch-smack him right there, but I kept my cool.
Old Apr 11, 2008 | 10:42 AM
GUMP's Avatar
GOLDEN NUGGET
Does anyone know if this is covered by the extended warranty I purchased thru Honda when I purchased the car. I've had other work done during the warranty. I'm assuming it's covered...I have the 100,000 mile extended warranty.
Old Apr 11, 2008 | 05:36 PM
bibledriver's Avatar
Something is missing...my
extended warranty will cover it. Mine did it too and like above posts, the mirror assy's were replaced and that fixed the problem
Old Apr 11, 2008 | 06:37 PM
GUMP's Avatar
GOLDEN NUGGET
Thanks, they forgot to call me back, so when I called he said, yes, they are covered. I have my baby back on Monday..
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
Sep 17, 2015 10:16 AM
