Side view mirrors -- ??
Old Feb 24, 2011 | 06:46 PM
blkonblk05TL's Avatar
Ok, so I've been searching around, and trying to figure this out.
The problem is I can't adjust my mirrors, when the left or right mirror is selected, neither will tilt down when the car is in reverse, and the heat function isn't working either.
The weird thing is that if I adjust the memory 1 or 2 -- or with the mem. 1 and mem. 2 keys, the mirrors will move how they were initially set.
Everything was fine, until the Acura dealer (closest to me) replaced both the mirrors (the glass) because they had scorch marks -- they were like that when I purchased the car as a CPO. Ever since then, this has been the issue. Now with the crappy winter weather, I'd like to have the heated mirror functionality, and miss the passenger side view mirror tilting when I'd parallel park. I haven't really been able to check the fuses -- although everything else is working fine i.e. wipers and their respective functions, or the chance to remove the kick panel/ lower portion of the dash to make sure all the harness is plugged in (maybe the tech forgot?), because it's been freezing out here.
Any ideas before I just start taking it apart?
Is there any easier way to essentially pop the plastic 'empty' switch to the right out to try and see/ plug in the harness that may not be plugged in?
Thanks in advance.
Old Feb 24, 2011 | 06:53 PM
Turbonut's Avatar
Certainly not a mirror expert, but I'd take it back to the dealer and let them correct the problems.
Old Feb 24, 2011 | 07:17 PM
whoops, I should of mentioned that the dealer that I go to, that is closest to me, is about two hours away..
Old Feb 24, 2011 | 08:01 PM
Turbonut's Avatar
Unless someone comes up with a possible solution, you may spend more time trying to correct the problem, but hopefully someone might afford some guidance.
Old Mar 6, 2011 | 11:37 PM
umakemekissu's Avatar
have you got the problem fixed? I have an 07 and having the same problem!! I'd love to here any input on this...
Old Mar 7, 2011 | 06:07 PM
yes i got it "fixed." the weather was finally hospitable, it took all of 6 seconds; i remove the lower portion of the 'kick panel,' it seemed as though the tech who worked on my car at acura didn't plug the harness back into the switch..
thanks acura tech!
BoricuaTL
Apr 8, 2016 01:08 PM
guitarplayer16
Nov 29, 2015 02:03 PM
Rocktman1
Oct 31, 2015 02:33 PM
Sep 17, 2015 10:16 AM
dre707
Sep 8, 2015 08:32 PM
