Side Mirrors Sticking/Shuddering During Auto-Tilt
Question about my '04 TL. I've noticed that both the driver's and passenger's side mirrors are sticking during the auto-tilt when the car is in reverse. Usually they make it 50% down just fine and then they seem to get hung and shudder the rest of the way down.
My service advisor told me that the only fix he knew of was to replace both mirrors. He wasn't sure if it was under warranty but that they'd heard of that problem before although not terribly common. During that same visit they replaced my transmission (for free) so when I picked it up today I didn't think to ask about the mirrors.
Is anyone else experiencing this problem? Both of my mirrors do it so surely someone else has seen it happen with at least one of their mirrors?
Thanks!
Thanks!
ugh...i have that same problem, but i haven't exactly done ne thing about it...
this is, i believe, the second or third set of mirrors i've had...dealership swap while i was under the warranty...
Registered but harmless
Received 1,148 Likes
I think the search is still not fully functional, so use Google if you want to try to pull up a couple of other Acurazine threads on this problem.
G/L.
...is there even a fix to this problem? i really don't know how you could really take the assembly a part, short from smashing the mirror completely off? then of course, I haven't seen the unit off the car - maybe there's a way in that way? i'd imagine there would be - something has to hold the unit onto the car right?
The DVD-A Script Guy
My guess on this is that there are plastic gears in the gear train in the actuator that moves the mirror. If the mirror gets stuck due to ice, debris or other "factors", it will skip and the gears will get some teeth rounded off. The more this happens the worse the rounding off and then even normal movement will cause skipping as the mirror moves. Vicious circle, skip is wear, wear causes skip.
I would think anything that could be done to reduce the moving friction of the mirror actuator would help but probably be short lived.
The actuator is about $50 and may be an easy DIY of not in warranty. Items 3 and 4 in this link
http://www.acuraoemparts.com/delray/...All&vinsrch=no
I had the same problem which existed for about a month and was looking to go to the dealer this Saturday. While at work I went out to my car to get some things and I curiously pushed up on the mirror thinking what if...
and guess what? problem solved. Adobeman is right. teeth on the actuator and the gears on the mirror seemed to be out of alignment. Try what i did and see if it fixes. just push the top part of the mirror by hand until you hear few clicks then get in the car and put it in reverse.
hope that fixes yours as it did for me... all by luck.
rockyboy
08-04-2024 10:35 AM
guitarplayer16
11-29-2015 02:03 PM
sockr1
10-01-2015 01:31 AM
