Shaking while braking issue...
Old Jun 6, 2007 | 12:29 PM
  #41
Will Y.'s Avatar
Registered but harmless
Originally Posted by mrlttran
How much should a brake job cost at an independant shop vs. dealer? I was quoted about 190 for the front and 200 for the rear with stock pads w/ resurfacing if required... I just want to use the stock pads as this car is for work and i drive around A LOT...
That's about the right range for a SoCal independent shop to do the work, including resurfacing.
Old Mar 24, 2011 | 10:14 AM
  #42
imj0257's Avatar
Q('.')=O
Epic BUMP.
I am experiencing this problem. I can feel my car shaking a little bit but only when I am breaking at high speeds, mainly on the freeway.
About 10k miles ago I replaced the front pads and rotors (did not replace the rear pads/rotors) and bled the brake system. About 1000 miles ago I got my tires rotated and an alignment. Any idea what could be causing this?
Old Mar 24, 2011 | 11:57 AM
  #43
Will Y.'s Avatar
...Any idea what could be causing this?
It sounds like slightly warped rotors.
If that's the cause, it's fixed by cutting/machining/turning/resurfacing the front rotors, resurfacing/machining the pads and using a torque wrench to tighten the bolts and lug nuts.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
prbori
Sep 27, 2015 01:37 AM
kingbharj
Sep 25, 2015 07:25 PM
