Shaking/vibration accelerate
Old Jun 7, 2013 | 09:15 PM
bimmer_w's Avatar
my 2004 acura TL 6 speed manual started vibrating/shaking during acceleration on all gears. once speed is steady no shaking/vibration going on. no shaking/vibrationg during braking as well. does anyone know if this is a known issue? i'm guessing its the engine/trany mounts.
Old Jun 7, 2013 | 09:45 PM
hybrid0175's Avatar
Most likely it's the axle. I had my passenger replaced. I guess it's a common issue.
Old Jun 7, 2013 | 09:52 PM
bimmer_w's Avatar
Is there an after market axle? Maybe something shorter than oem since my car is lowered
Old Jun 8, 2013 | 07:31 AM
Project_CLean's Avatar
MMkay.
My guess would be axle. Same problem on my car.
Old Jun 8, 2013 | 08:58 AM
bimmer_w's Avatar
But the axle are not making any noise even when turning
Old Jun 8, 2013 | 09:54 AM
hybrid0175's Avatar
Mine didn't make any noise, that i recall, before it was diagnosed and replaced by the dealer.
Old Jun 11, 2013 | 11:43 AM
Mafyoso's Avatar
Balling in the...
I have the same issue with my TL-S Automatic. When I haul ass front end shakes but when Im driving at a steady pace nada. So ya think its the axles?
Old Jun 11, 2013 | 12:06 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
axle. clicking comes from worn outer CV joint. vibration under acceleration can be from worn inner CV joint. i've had both on my car.
Old Jun 11, 2013 | 01:18 PM
TWiSDiT's Avatar
Chapter Leader (Mid-Atlantic Region)
shaking where? i had a similar problem. my front motor mount and upper trans mount were cracked. replacing them helped a lot. My lower trans mount look cracked too. still need to replace those
Old Jun 11, 2013 | 03:55 PM
Mafyoso's Avatar
Balling in the...
well its kind of a tremer On the front end of my car. Kinda the feeling you get when you have warped/egged tires. I know its not the tired cause they are brand new. I changed them thinking that was the problem
Old Jun 12, 2013 | 09:01 PM
jvieira21's Avatar
100% cv axle I had the same problem and replaced both axles and the vibration went away. You have to change both axles
Old Jun 12, 2013 | 09:20 PM
bimmer_w's Avatar
Yes you guys are right. I did checked the axle and the passenger side has a lot of play. The driver side has some play as well but not as bad as the passenger side. Any recommendation as to what axle I should purchase?
Old Jun 13, 2013 | 09:05 AM
MMkay.
OEM! The ones for the 6MT aren't too much money.
Old Jun 17, 2013 | 11:49 PM
ed99's Avatar
9.5+10.5 22m=Hella Flush
Anyone installed after mkt axle since the Oem ones cost over $600 per side?
Old Jun 18, 2013 | 09:29 AM
MMkay.
I posted about this in a similar thread. If there is an Autoparts International around your area, they sell ones for your AUTOMATIC TRANS. for a little over $100 i believe. The only reason i vouch for these is because we use them at the dealer I work for on the Auto. 3G TL's since customers don't want to spend that much for an OE. Although,ones for the 6MT are only a couple of hundred straight from ACURA.
Old Jun 22, 2013 | 08:35 AM
Gryphen's Avatar
Wallet raped by my
I just recently started having this problem also. Mine is also a tremor feeling and is extremely noticeable, almost violent feeling from about 52-62mph. The car has 207K miles. I had a couple people tell me they thought it was motor mounts. Looks like I need to get on the lift and check.
Could it possibly be both? If so which should get repaired first?
Old Jun 22, 2013 | 08:59 PM
bimmer_w's Avatar
i had my axle replaced yesterday. the scary tremor was gone but there is still some vibration during acceleration. i pulled out my front wheels this morning and found both lower control arms bushings ripped. will this cause some vibration during acceleration?
Old Jun 22, 2013 | 09:25 PM
paperboy42190's Avatar
it will if its bad enough to cause a lot of play
Old Jun 24, 2013 | 07:39 AM
MMkay.
I feel like if it was the bushings causing the vibration, it wouldn't be just upon acceleration. It should be during braking as well..? no?
Mike734
Dec 10, 2021 01:25 PM
mlody
Dec 4, 2019 02:11 PM
joflewbyu2
Aug 18, 2019 10:38 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
