Severe Fluid Dump
So....I crossed 100K of ownership today and I think my car is on it's way out.
I hit a road gator on the way to a customer. First customer of my new job. It missed the body but hit the bottom of the engine compartment. No issues right away but I pulled over right after to gas up.
I didn't see anything at the station or when I stopped for a coffee. Right after I was pulling on to the highway and it felt stuck in first gear. Engine raced but I could not shift at all. Car never overheated and no warning lights came on.
When I pulled over it basically was dumping fluid. I found transmission fluid, coolant and washer fluid.
I suspect the road gator cracked the radiator and the washer fluid tank. Not sure what else cause all that.
Any other suspects?
Any other suspects?
The washer fluid seems odd, but I do have a theory on the ATF and Radiator fluid. My Honda Pilot had a severe loss of fluid and it turned out that the ATF line that runs to the radiator corroded and broke off the radiator- it was a clean break at the radiator. The fix was a new radiator and new ATF in the transmission and all is well.
Verdict is in....issue is worn fitting that caused it to come apart. They cannot confirm nor deny that the gator did it but said it is not likely. They said they have seen this before.
The tech said it will be about 1000 but I did not have any fluid mixed in the transmission or the radiator so I should not have any issues down the road.
So the issue was that one of the inlet tunes that connect to the lower part of the radiator broke completely off. There was corrosion so it is not likely that the tire did it. The fluids I saw was the coolant and the transmission fluid. Not the washer fluid.
The radiator was 340. And I needed to replace all the transmission fluid and coolant.
I'm sure I could have gotten it done cheaper or do it myself but I did not have the time to do it myself.
SidhuSaaB
May 30, 2020 12:40 AM
