SERVICE BULLETIN LISTING-CHECK IT OUT AND SEE IF YOUR PROBLEM IS IN THERE
Service Bulletin Listing-check It Out And See If Your Problem Is In There
Edit by mod Ron A
First, let me thank loud_whispers, on behalf of the 3G TL community, for all the work he put into this and for posting this information.
I have closed this thread because if we allowed posts in here, it would be a mess trying to figure out which reply went with which TSB.
If you wish to post replies, comments or questions to any of the bulletins listed, please start a new thread and cross reference it to this thread and the TSB you are writing about. This will keep similar topics in the same thread.
Additional TSB's can be found by clicking here and lots of other good and helpful information can be found in the 3G Garage
SB#05-033: Power Mirrors, Auto Dim Mirror, Power seat memory, Washers INOP (fix)
Very Common on 04-06 TL's. Im sure most of you have the problem or have had the problem, wondering a fix. Or you took your car to the dealership and wondering how they fixed your problem.. Here's the Bulletin. Enjoy!
http://www.in.honda.com/Rjanisis/pubs/SB/b05-033.PDF
SB#05-025: Outside Air Temperature Guage Reads Innacurately.
Here's another bulletin for you guys. Common on TL's. Most of you have probably taken your car to the dealer already for it.. For those who need it, here it is..
http://www.in.honda.com/Rjanisis/pubs/SB/b05-025.PDF
cheers.
cheers.
SB#05-017: 5th Gear Vibration or Drone
5th gear vibration on highway, applies to all 04 TL's A/T. Here's your fix!
http://www.in.honda.com/Rjanisis/pubs/SB/b05-017.PDF
good luck..
good luck..
SB#05-020: HandsFreeLink (HFL) System Does Not Work.
Here you go guys.. for present and future references.
http://www.in.honda.com/Rjanisis/pubs/SB/B05-020.PDF
Good Luck.
Good Luck.
SB#04-043: Rear Shelf Rattles.
Very common. Here is 3 of the possible fixes that we do. I don't encourage anyone to do these service bulletins unless you aren't covered under warranty which most of you are. This is just a general knowledge and for future references when your warranty expires.
http://www.in.honda.com/Rjanisis/pubs/SB/b04-043.PDF
good luck.
good luck.
SB#04-019: Brembo Brakes Squeal with Light Application
Common. 6MT guys..this is the fix, get it under warranty if you can at your local dealership.
http://www.in.honda.com/Rjanisis/pubs/SB/b04-019.PDF
cheers.
cheers.
SB#04-039: Headliner Sags at Moonroof Opening.
General Inspection.. Also a guide to take your headliner down.. Take it to your dealer if your under warranty. Don't attempt unless confident or when necessary.
http://www.in.honda.com/Rjanisis/pubs/SB/b04-039.PDF
regards.
regards.
SB#04-034: Moonroof Wind Deflector Rattles
Common on some that even fall out of the VIN range that i've seen. So if this applies to you, here's your fix.
http://www.in.honda.com/Rjanisis/pubs/SB/b04-034.PDF
luck.
luck.
SB#05-016: Roof Console Bezel is Cracked or Broken
chemical contamination. may apply to you..
http://www.in.honda.com/Rjanisis/pubs/SB/b05-016.PDF
cheers.
cheers.
SB#05-018: Navigation System DVD Information
SB#04-005: Drivers Position Memory System Does Not Work.
Sb#03-012: Immobilizer System (Type 4)
04' TL- ALL
04' TSX- ALL
This is everything you need to know about your Immobilizer system.
http://www.in.honda.com/Rjanisis/pubs/SB/b03-012.PDF
Enjoy.
04' TSX- ALL
Enjoy.
SB#05-076: Premature Tire Wear
Bridgestone tires. Too Much Junk in the Trunk!
Note: please FULLY read the bulletin to see if this applies to you.
http://www.in.honda.com/Rjanisis/pubs/SB/B05-076.PDF
cheers.
cheers.
SB#97-040: Keyless Remote Transmitter Information.
Everything you need to know about Keyless transmitters.
http://www.in.honda.com/Rjanisis/pubs/SB/b97-040.PDF
enjoy.
enjoy.
SB#05-029: Outside Temp. Displays Three Dashes(---) or Intermittent Dead Battery.
SB#04-036: Homelink Unit Does Not Learn Garage Door Opener Code.
SB#04-011: (02-04 RSX) Squeaky Clutch Pedal
Bulletin is for the RSX, but it's the same fix for all MT Acura vehicles. It's either the clutch master cylinder or the throwout bearing.
http://www.in.honda.com/Rjanisis/pubs/SB/b04-011.PDF
enjoy.
enjoy.
Zonian22
11-14-2015 01:20 PM
asahrts
09-04-2015 05:55 PM
