Serpentine Belt of DEATH!
Old Apr 10, 2022 | 03:02 PM
Stocker_07's Avatar
What's up everyone! I'm trying to figure out this issue I'm having on my 08 TL 3.2, I'd post videos but I'm a newbie and don't know how.
I just replaced the timing belt and ran it without the accessory belt to verify proper running
before I put it back together and it ran fine, no codes or misfire. When I put the accessory belt
back on it runs very rough and ended up throwing a PO389. Now the car is back together, I can go back and
forth removing the belt and the symptoms are the same. All pulleys spin fine and I have verified proper belt
routing time and time again.
Any help I can get with this would be greatly appreciated!
Old Apr 10, 2022 | 06:47 PM
Maybe revisit and recheck timing and connection to the crank sensor if it was unplugged?
P0389 - Acura Diagnostic Trouble Code (DTC) Definition, Causes and Diagnosis (dtcdecode.com)
Old Apr 11, 2022 | 06:50 AM
Stocker_07's Avatar
It's possible but could that explain the symptom of the running rough/running good with the belt going on and off?
Old Apr 18, 2022 | 09:17 PM
Chad05TL's Avatar
is it possible the crankshaft got rotated by 1 tooth while installing the timing belt? I hate to say that! lots of work to check
Vannertoo
1G RL (1996-2004)
Oct 10, 2017 09:14 AM
eyesnake02
Mar 21, 2013 06:56 AM
CivicB18B1
Feb 24, 2009 04:30 PM
dougal813
1G TL (1996-1998)
Mar 13, 2004 01:06 PM
