Security won't arm (no flash or beep)
Old Apr 25, 2012 | 07:05 PM
Beardown1's Avatar
6th Gear
I have looked at similar threads and still cant figure this out. '04 with Navi.......MID is set to beep.....all doors lock and unlock fine.......hood and trunk are both shut......all fuses look okay. I even unhooked the hood switch to see if that would make a difference, but still no beep, light flash or driver door security lock flashing red LED. Anyone know exactly which fuses to check? Any other suggestions?
Thanks!!
Old Apr 26, 2012 | 10:08 AM
jda123's Avatar
Dogmatic Dinosaur
Check the battery in the remote first.
Old Apr 26, 2012 | 12:00 PM
Undying Dreams's Avatar
Double check the hood and trunk. It happened to me, I adjusted my headlights one night and it was slightly open the day after, kept it from flashing and beeping also.
Old Apr 29, 2012 | 08:39 PM
Beardown1's Avatar
6th Gear
Bump............C'mon guys........there has got to be some additional info/suggestions. The battery is new and I am sure the hood and trunk are closed. I do notice a whirring sound sometimes from the driver side rear lock, but it always locks/unlocks fine...........HELP!!!!
Old Apr 29, 2012 | 09:04 PM
guitarplayer16's Avatar
My TL did this when my driver door lock actuator went out.
Old May 1, 2012 | 10:14 PM
MyFreakGSR's Avatar
just because it locks and unlocks doesn't mean the sensor inside them isn't bad. I would start with the one making noise. common problem in TL's.
mlody
Dec 4, 2019 02:11 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
adreano17
Sep 29, 2015 08:48 AM
thegipper
Sep 28, 2015 01:01 PM
Brandle34
Sep 23, 2015 07:20 PM
