The Seat Memory Isn't Working Anymore
Acura TL NBP
The Seat Memory Isn't Working Anymore At The Driver's Door. Since I share my TL I have to manuelly move my seat each time how can I fix the memory seats?
Stay Out Of the Left Lane
Received 1,237 Likes
You may want to look into this TSB -
http://www.in.honda.com/Rjanisis/pubs/SB/b04-005.PDF
I don't know if you dealer will cover it, but it might help with the diagnostics.
It might also be a fuse (#20). If the green light in your rear view mirror is out and your windshield washer doesn't spray, then it's this fuse. There was a TSB to change this fuse from a 7.5A to a 10A fuse (TSB 05-033)
If you haven't had the previously mentioned seat memory TSB done, I'd see if the dealer will do it on a goodwill basis.
At any rate, have you tried to reset your seat memory using the procedures in the owner's manual, pg 93? Does the seat memory work for the other FOB?
acura master tech
press the lock and unlock button on your key fob to re link it. close the dooor. lock it. unlock it . get in. turn to acc and it should say drivers 1 or 2 . the key fob says 1 or 2 on the back as well.
TL Nub
@nfnsquared: Gonna try this in the morning. I verified that the rear view mirror light when out and noticed that the washer wasn't spraying a week ago. Didn't realize they were related. Maybe this will fix my mirror issue, as well? When I reverse, neither mirror turns even when I have the switch shifted left or right. Also, I can't adjust my mirrors to the outside. They only turn down and in.
@240sx: Tried that but it didn't work. Thanks for the info though!
i know how u feel man, i had the same problem and didn't know what to do! i guy i know checked it for me and found out it was a fuse, as a result, the mirrors started tilting, washing fluid started coming out and memory seat started working also~!
Well, you now know how easy it is to fix. Be sure you replace that fuse with a 10A fuse instead of the 7.5A.
[quote=mackymacalincag;11674665]nfnsquared - are you positive about upping the amperage?
Here is a link to the TSB, check if it is applicable to you:
http://www.in.honda.com/Rjanisis/pubs/SB/b05-033.PDF
[quote=Oracle_Oracle;11674716]
Thanks that makes a whole lot of sense.
Macky,
Sorry, I assumed one would have read the entire thread and digested the necessary info.
My windshield washer spray wasn't working. Then a few months later my mirrors stopped working, then my memory on the seats later after that aswell. I changed the blown fuse # 20 the ig washer, as named on inside of cover. And the washer pump started working, my memory seats, and the power mirrors aswell! Hallelujah!
I had my Seat memory, Rear view mirror and my Side mirrors would only go down and to one side which was strange to me replaced it with a 10A and it works. Thank you so much.
