S/C Drive Bracket Shim Backing Out
Old Mar 24, 2009 | 02:28 AM
ImPo Skyline's Avatar
Registered Offender
Is anybody else having this problem? The thin white plastic shim that mounts
between drive shaft housing and the outer shaft housing bracket keeps backing itself out. It takes about 2500 miles to almost completely back itself out. Here's a picture of where the shim is located,
Old Mar 24, 2009 | 02:38 PM
Hi speed's Avatar
runnin a little boost
No, did you install the blower yourself? I can't even see mine it is so far back in there. I would look at the bracket it is attached to and see if it is loose or mounted wrong.
Feb 25, 2020 09:57 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
justin7779
Dec 25, 2015 10:33 PM
nanos
Nov 12, 2015 08:41 PM
KillerG
Sep 4, 2015 02:02 PM
