Running rich? No CEL
Old Feb 23, 2016 | 10:18 PM
jon.mar27's Avatar
07 TL
Can smell the car is running rich, checked the spark plug they look perfectly normal, my "tighten fuel cap" msg came on so changed the purge valve
No CEL, I don't have loss of power either, actually runs better, but waste more gas...I was thinking egr valve...if it is what can I clean it with?
Kind of stressful not knowing what it is..
Old Feb 23, 2016 | 11:26 PM
csmeance's Avatar
best thing to do is get a hookup on the OBDII port and see what the A/F ratio is according to the sensors on the car.
Have you run a fuel cleaner at all? Dirty injectors can cause fuel to not atomize properly leaving fuel unburnt. What's the mileage?
Old Feb 23, 2016 | 11:49 PM
jon.mar27's Avatar
yea I put a Lucas cleaner, that comes in the small bottle last fill, put another with my half a tank I have now, and I just got a sea foam, so when I run to empty Ima fill it up compelety again and put seafoam in it.
There's no misfiring (at least to my knowledge, and I feel everything when I drive or sit at an idle) that's happening, so I would believe if it was a injector it'll misfire, no?
Old Feb 23, 2016 | 11:52 PM
jon.mar27's Avatar
Almost 122k miles
Old Feb 24, 2016 | 12:06 AM
csmeance's Avatar
Originally Posted by jon.mar27
Almost 122k miles
when is the last time spark plugs were changed? 105K is the usual time they are changed. Also when is the last time you got a valve adjustment?
Old Feb 24, 2016 | 03:29 AM
jon.mar27's Avatar
I changed the spark plugs with the last oil change, no more than 2k on them I check those and they seem to be perfect, and was thinking of getting my valves adjusted but motor is quiet, I'm starting to think something with exhaust (resonator, cat converter)
Old Feb 24, 2016 | 03:32 AM
jon.mar27's Avatar
I know I'm not going crazy cause even a couple of my friends that's near my car after running it or at idle tells me it smell like it's running rich
Old Feb 29, 2016 | 02:40 PM
F(x)'s Avatar
Might be your evaporative system.
carbonTSEX
2G RDX DIY & FAQ
Jan 26, 2017 01:00 AM
