RPM shift problem
Old Nov 3, 2011 | 08:04 PM
acuradrivertls's Avatar
5th Gear
RPM shift problem
hey guys i need some help and advice. im wondering if anyone has experienced this problem that im having with my car. i have an 07' tl type s automatic (tiptronic).... when i punch it from a stop or a roll and the rpm revs past 5500k i get a jumping needle like if theres a limiter there then after like 2-3 jumps on the rpm it then shift into the next gear. (automatic) when i drive it in tip-tronic it does the same thing but instead i have to shit if into the next gear obviously... but after the 2-3 jumps then in continues to redline.... one last thing... without punching in (WOT) like easing into the high rpms.... i dont have this problem .... does anyone know what this is?? how to fix it?? y i have this problem??? HELP PLEASE!!!
Old Nov 3, 2011 | 10:18 PM
vietxquangstah's Avatar
I don't really understand what you are saying... do you think you can capture it on video to show?
Old Nov 3, 2011 | 10:30 PM
kingkong_dav's Avatar
KingKong_Dav
i know what u r saying. HAHA upgrade to a better ATF. stay away from redline just get Vavloline Maxlife ATF or Mobil 1 ATF. HAHAHA better do it soon before its too late. HAHA im laughing because it happen to me
Old Nov 3, 2011 | 11:25 PM
ez12a's Avatar
the overexplainer
transmission's slipping. better do the fluid swap and switch changes asap. worst case scenario you need a rebuild due to the wear on the clutch packs.
Dont go driving up a steep hill. Fried my parents' Odyssey transmission going up a hill on the fwy.
Old Nov 4, 2011 | 11:30 AM
5th Gear
damm..... i will try to get a video but i dont want to do it again.... so i need to change the TRANS. FLUID ASAP??
Old Nov 4, 2011 | 11:47 AM
ez12a's Avatar
the overexplainer
it's really the least you can do to save the transmission.
If it's a dirty pink it definitely needs replacing.
Old Nov 4, 2011 | 03:28 PM
5th Gear
thanks..... i spoke with my dealer, i will take it in for "B" service (b/c the light came on) and i mentioned it to him... they will look at it . worst case if its the transmission that has to go, they will give me a new tranny under warranty. so its either full "B" service with a ATF swap or full "B" service with a NEW TRANS... hope this fixes the problem.
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
DidiBob
4G TL Problems & Fixes
Sep 23, 2015 08:14 PM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
